Hey everyone.
Just wondering is it possible to put a later model LSD into a IRS VP?
What models can i do this with?
Will they bolt straight on?
Do i need other parts with it other than the LSD?
and the price range?
Any help would be great![]()
Click the link
diff, all you need to know
sweet as thanks mate, ill have a good look![]()
If it helps you mate... Yes you can fit the M80 from the later VT, VX, VY.
You just need to change to the earlier pinion flange, and also dock off the extra length on the pinion bolt
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
yes this does help thanks mate, what is a pinion flange and bolt??
VP For Life!!! haha
You know where the tailshaft bolts to the diff? thats the pinion flange, or yoke is the proper name i think.... VN- VT1 had a round steel 4 bolt flange. later models had a rubber donut link, 3 bolt i think.
When you remove this flange from a later model, there is like an inch or so of extension on the end of the bolt underneath that centers the rubber donut. When adapting the earlier flange (as above) to this that extra extension simple gets chopped off. you can actually do this yourself. BUT if you're not sure i recommed seeing a diff specialist.
ah yes i understand that now, when the time comes when i do, do this ill have the sqecialist do it or look and tell me what to do, whatever will be easier at the time.
thanks mate, this really did help.
Im finally gettin around 2 fitting my LSD Diff into the VP calais, now ive found out that mine will bolt straight up 2 the tail shaft no worries, but seems with my drive shafts i dont have the bits that the drive shafts bolt 2 in the diff or do i?. can the bits from the diff in the calais atm fit into the LSD diff? that just has the standard 3.08 single peg diff in atm or do i need 2 get 1ns 2 suit? wat r these parts even called?
i can answer my own question haha yes they did fit straight swap no worries.
Tho just wondering if any of u guys can help with a knocking skipping noise im gettin now after its been installed. Ive noticed mainly after been 4 a drive so mayb after the diff oil warms up? wen backing in the drive way and having the steering wheel turned slightly or alot so its not driving straight (does it driving very slowly forwards 2 just not as noticable) the diff makes a light but noticable skipping, shuddering sound. 1st i thought oh no better not have been giving a spool. has any 1 heard about this? is there such a thing if the diffs too tight? it has been rebuilt apparently 4000kms ago but atm it feels kinda like a spool in some way? it doesnt really sound like the tyres r skipping i dont think but somthing else? the strange thing is as soon as i am driving or reversing dead straight it doesnt do it
A freshly built LSD that is set up 'tighter' that factory spec will skip a bit when first driven. Its called bind. As long as you have used proper LSD oil suited to these LSD's you will be fine.
When i first drove my VN with completely rebuilt LSD i drove out the driveway and it shuffled exactly like my track car (that has a spool). it was like that for about a week, approx 350kms. if it bothers you too much just pour in a bottle of Penrite LSD additive.
I picked up my newly built M80 for my SS yesterday, im expecting it to be the same as my VN.
yours should settle in after a bit. Good thing is you have a tight LSD on your hands!
I recommend you flush the oil after about 1000km, just to clear out the lapping paste and the dust from the cones bedding in.
Oh true thats great news, tho saying that from wat the guy said 2 me b4 i bought it, the diff was re build 4000kms ago so wouldnt it have settled down by now? mayb the guy i bought it from didnt know wat he was talkin bout specially after he said it had different gears in it and it hadnt. could it have been the mechanic who installed it didnt do somthing quite right? but it definatly sounds like wat ur talking about. I'll just drive it around 4 a couple weeks and see how it goes.
They all settling in differently. if its done 4000kms and still binds, it most probably needs the LSD additive.
You would know if its not in installed correctly. It would make noise constantly, not just on tight corners
Yea must be set up really tight. Thats what a spool does usually. Sure its not a spool??? lol
this is what my diff guy recommends: LIMSLIP ADDITIVE 7098 - Penrite Oil
Or this... Manual Gearbox and Diff Treatment- Nulon Australia
cheers i'll go get some of that and see how we go.
well i thought that but a member on here said if it was a spool and i turn it on hard lock it'll act like a hand brake and i wont go anywhere in drive? mine moves on had lock so i kinda ruled that out. i wouldnt have a clue how else 2 tell if its spooled or not.
