Results 1 to 7 of 7
Thread: Spare tire well?
    vn calais 5.0
    Jun 2011
    victoria
    Default Spare tire well?
    Off to the wreckers today to cut another spare tire well part out and was wondering if the vn to vs is the same or just the vn to vp?
    vn calais 5.0
    Jun 2011
    victoria
    Well the tire well is worse than I thought so I made some patches and will have to get it cut out and replaced.. Where can I get the new patch pannel from?
    Xw GT replica/Vr s ute/Ef
    Jul 2011
    NSW
    I would just bog it up. The vn vp vr vs are all the same. Good luck with fixing it btw cheers Travis
    vn calais 5.0
    Jun 2011
    victoria
    Thanks Travis.. Made tin patches then silicone it and pop rivit on to keep the water out.. Painted it black too so it's not so sus.. Might have a go at fiber glassing it from the out side?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    just slap some body deadner on the outside if your going to bodge it up.
    Jul 2011
    NSW
    Hi mate i would just tar it real thick over the repairs. btw the rust there 9 out of 10 have it so its common cheers
    vn calais 5.0
    Jun 2011
    victoria
    Saw a few bad at the wreckers and a couple of clean.. Will just tar it out side and inside too.. That should keep it good for a while..
  1. tire pressure
    By lion_g in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2011, 09:39 AM
  2. Tire Size
    By joe seinfeld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2010, 10:00 AM
  3. Tire Wear?
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2006, 05:06 PM
  4. spare tire
    By Kuzzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2006, 12:30 AM
  5. Tire Question
    By Warooda in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2005, 05:59 PM
