Results 1 to 4 of 4
Thread: How to remove crossmember to get remove oil pan VN V6
    VN Commodore
    Jul 2010
    Hervey Bay Qld
    Default How to remove crossmember to get remove oil pan VN V6
    Need to remove oil pan from engine but need to remove to crossmember has anyone done this before that can tell me how (pics would help on where all bolts are) thanks
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    You need to lift the engine rather than dropping the cross-member.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    few commodores
    Feb 2011
    victoria
    easier to unbolt the engine mounts and raise the engine, should be able to lift it enough before the tb hits the firewall to get enough clearance, if not enough room then you'll have to undo the tailshaft, block the extension housing to avoid fluid loss, undo rear x-member and drop the back of the gearbox on a jack to angle the engine up more.
    compared to dropping/undoing the k-frame/entire front suspension, as you'd have to support the engine from above to do it that way anyway
    after explaining all that, i remember why i remove the engine and trans completely to do this kinda work
    VN Commodore
    Jul 2010
    Hervey Bay Qld
    thanks guys you've been a big help
  1. To remove rear muffler or not to remove?
    By 1FATVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-11-2010, 02:57 PM
  2. How to remove
    By Gorrell72 in forum VE Holden Commodore (2006 - ?)
    Last Post: 06-11-2010, 11:33 PM
  3. How to remove...??
    By Fun_Bucket in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2009, 01:36 AM
  4. About to remove this....??
    By nicko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 11:53 PM
  5. should i remove IRS
    By fraesralj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 06:29 AM
Tags for this Thread
