Results 1 to 12 of 12
Thread: AC compressor on and off and on and off
    VP Commodore S2
    Nov 2011
    victoria
    Default AC compressor on and off and on and off
    Just wondering if this is normal,
    On a really hot day, I turn my AC on, the compressor kicks in, and you can hear the relay turning on the engine fan. Then 10 seconds later, fan off, compressor de-clutches, then 10 second later on again. 10 second is a rough estimate but it just keeps going on and off.
    Yeah the car cools down, and nothing major happens as a consequence, but the lurching forward when it clutches and declutches and the sudden drop/gains in revs and speed when it does really starts to piss me off eventually.
    Normal, or not?
    It's a SII VP V6 exec btw
    Thanks
    few commodores
    Feb 2011
    victoria
    sounds like it's low on gas and the low pressure switch is turning the system off to protect it
    (or the other way round and to much gas and the high pressure switch)
    i'm thinking low pressure though as my vn was doing similar but not as bad before i topped it up and when a gauge was connected to check the level it started turning on and off in about 5 second intervals with the loss in pressure
    VP Commodore S2
    Nov 2011
    victoria
    I'd Acrually say the latter coz I had it regassed less than 2 months ago.
    But that can't be right coz some days it's fine some days it's not, either way it ends up cool.
    Also, it tends to be worse on hot days.
    Couldn't have leaked out coz when I had it regassed it still had 650gms left (only 200 lost) since the previous regas in 2006
    few commodores
    Feb 2011
    victoria
    ah so it's had work, try replacing the low pressure switch on the dryer/filter, they have a tendancy to fail and play up like this then
    possibly the overheat sensor on the compressor or the high pressure side switch
    few commodores
    Feb 2011
    victoria
    VP Commodore S2
    Nov 2011
    victoria
    Retrofitted to r134a in 2006 and refills last year with r134a
    How do I find/see if they've failed with those sensors?
    89 vn calais v6
    Oct 2010
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    few commodores
    Feb 2011
    victoria
    low pressure switch in on the filter/dryer.... well it is on the r12 system, round cylinder up near the firewall, when it starts doing it again, unplug the wire going to it and short the plug with a paper clip/piece of wire, if it comes on and doesn't cut out then it's that sensor/switch. If replacing it be quick, there's a valve behind it so you'll lose a small amount of refrigerant, replace the Oring also at the same time, when installing once again be quick, also wear gloves and don't put your face near it, freezer burn is bad.
    high pressure switch is up near the condenser, i'll have to go have a look at one to check if it should be open or closed state, but it's usually the lp switch.
    DO NOT SHORT THIS OUT PERMANENTLY IT'S THERE FOR A REASON AND SAFETY IF THERE'S A PROB IN THE AC UNIT IT TURNS IT OFF.
    few commodores
    Feb 2011
    victoria
    found another cause for this by accident today.
    replaced the rh head light in a car and after i'd finished started it up to align the headlights and heard the ac cycling on and off repeatedly..
    first thought was oh crap. I'd just overhauled the system as regassed it a few weeks ago and didn't feel like doing that again as i was sure i'd replaced everything needed.
    Started at the lp switch and this wasn't it and then noticed the engine fan wasn't coming on, the plug was in bad shape and when i installed the headlight it had been bumped, fixed this and it's working 100% again.
    so check for sufficient airflow through the condenser and radiator and make sure the fan is coming on with the ac.
    VN Exectutive 1990 3.8
    Mar 2010
    Hey mine was doing that too along time a go,off on off on especially on hot days and then it stopped completely, some idiot mechanic told me it was low on gas and that my compressor was stuffed he didn't even check it, told me about $1100 to fix and that included regassing and new compressor I told him no thanks, anyway I took it to a automechanic and it turns out its that little switch behind the front grill he called a low pressure switch, he replaced it and it's been right as rain ever since ))
    VP S-Pack 2nd Owner's Avatar
    VP S-Pack 2nd Owner is offline smarter not harder
    VP S-Pack Oct '91 Pathfinder R50 V6 '97
    Apr 2011
    South East Queensland
    Cool Be Cool
    Hi vpcomm92,
    This is a common issue with our cars, so unless you’re in a good mood & have decent audio to boot, it can be quiet irritating, I switch A/C off when the need for rapid speed is required... I put new ECU in 2years ago & have replaced low pressure switch, TX valve, re-gassed system, UV dye in compressor oil to check system for leaks, new O ring, vac test - all OK – cabin temp can get as low as 6 degrees – still works great!
    The compressor clutch engages at short intervals (every minute or so) & excessive wear of the compressor is the root cause - ECU controls the frequency of A/C compressor to balance power load, so the solution is to bite the bullet & get a Genuine Sanden Compressor (AC 102G), do your research in your local area for a decent Auto Electrician - A/C workshop to fit & test properly with warranty.
    ..a dimension, not only of sight and sound, but of mind - a journey into a wondrous land whose boundaries are that of imagination..
  1. air con compressor
    By macka_21 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-11-2011, 08:40 PM
  2. VT Air Compressor
    By DeiCide in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2011, 09:47 AM
  3. WTB: Gen III Air con Compressor
    By Tom_1569 in forum Swap / Wanted to Buy / Trade
    Last Post: 18-04-2008, 08:47 PM
  4. WTB - VT 5L A/C Compressor
    By STEALTHY™ in forum Swap / Wanted to Buy / Trade
    Last Post: 04-01-2007, 10:04 AM
