Results 1 to 8 of 8
Thread: Leaking boot on VP sedan
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    Default Leaking boot on VP sedan
    Doing a bit of work tidying up rust spots around the boot lip and rear windscreen and trying to eliminate the last water leak into the driver's side of the boot area. Have sealed the taillights and dealt with a few small rust holes in the boot lip. Also sealed behind the hinge for the petrol cap cover and the rubber flange around the fuel tank filler pipe. There still seems to be a leak perhaps from under the little cover piece on the bodywork at the bottom of the rear roof pillar. It feels like plastic of some sort and I assume it is covering a weld or join of some sort.
    Can anyone tell me how to take that cover off and what I might find underneath it. If there is a rust hole under there I would rather treat it to stop/slow it rather than trying to seal the edges of that little cover and having the rust continue underneath.
    I'm using POR15 paint system to treat the problem areas.
    cheers and thanks
    few commodores
    Feb 2011
    victoria
    the rear quarter glass windows are known to be a problem with leaks in vn/vp's also
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Feb 2011
    nowra, NSW
    thanks for that. I've done a bit of work around there too and it feels like with every area I've sealed the leak gets less but it's still there
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    one leak that i found was coming from the boot garnish loom rubber. the rubber grommet that the number plate light harness passes through. when i water tested my calais to find the leak i saw that there was a little gap where the electrical tape wasnt tight enough and the water followed the wires right into the boot. tape it tighter or just smear a glob or urethane in the gap of the tape opening.... i did this and dont nave anymore leaks....
    dont sweat the petty... pet the sweaty...
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    hj kingswood
    Sep 2011
    Melton
    There's 3 holes behind that cover, it is plastic and you'll have to be careful not to break it, get a spare just in case, mine had sikaflex behind it and 3 clips into the holes, overkill I think, but it is a join, the por15 system is awsome, but I wouldn't use any other product they sell. I've been told it's shit and expensive.....
    Feb 2011
    nowra, NSW
    Thanks for all the responses fellas. Happy and inclusive Australia Day
  1. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  2. leaking boot
    By Muzz-VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2008, 10:22 PM
  3. VT Boot Leaking
    By cr212 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2008, 11:23 PM
  4. boot leaking
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 05:50 PM
  5. VK Boot leaking
    By VKNutt in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-03-2006, 02:50 PM
