Hi guys,
Simple question, Wanting to know if I can use VN switchblocks in a VP? I know the hazards and dimmer changed sides, but I want to put an L3 cluster in, and the VP ones use a BCM, so no spring click. If I ust the VN Calais trip switch block and then standard VN RH block, and just extend the looms across, can I use them?
Thanks
PS Avoiding doing the VP SB mod at all costs :P
You will need to change the bottom switch on the PCB. If you like you can send me the 2 switch blocks and I will convert it for you - cover the job with a bit of postage.
I have several already half done so wont take all that long and then you can wire th whole job up and get it all workiing as it should. PM me and Ican do the name and address thing![]()
and 3 Dangerous non ABS VN's
That'd be sweet![]()
In the case if I sent a standard VP SB and a L3 VP SB would you be able to do that mod?
Just got to manage to find the L3 one now![]()
