Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By hi_ryder
Thread: VN Fuel Gauge...And temperature....
    VN Commodore Wagon
    Jan 2012
    Illawarra NSW
    Default VN Fuel Gauge...And temperature....
    Hey guys, this may seem like a dumb question to you all, and I haven't yet run this past my Brother (who knows about Commodores) or my father, but :
    1) My fuel gauage is a tad dodge. It works and all , but if you go up a hill, the gauge reads you more then what it does on the flat, and going down a hill, reads less. Is this a common problem in older cars?
    Any possible suggestions as to what the problem could be
    And Number 2 , isn't a problem as much, but My temperature gauge , even on a hot day , won't read past the 2nd bar on the temp gauge (so not in the "normal" zone) but most times stays below the first bar......Also is that normal?
    I know these may sound like dumb questions, but bear in mind, it is my first car and Commodore
    Thanks heaps for any advice you guys may have
    Got my First car---VN Wagon
    Coming from a family who owns a Camaro and 2 Monaros.....It made sense to buy a Holden and not a ford.
    Love my photography ,especially car photography !
    few commodores
    Feb 2011
    victoria
    Normal and Normal, The sender in the tank is closer to the front, going up or down hill will change where the fuel is sitting in the tank, i'd think it was the other way around to what you've described as going up a hill would move the fuel to the back of the tank and away from the sender/float and downhill should make the fuel run to the sender raising the float.
    most commodores sit on the 2nd bar of the temp gauge (well all the ones i have driven anyway) unless there's something wrong or it's a really hot day and your thrashing the crap outta it it normally doesn't go any higher.
    VN Commodore Wagon
    Jan 2012
    Illawarra NSW
    yeah I could of had it mixed up , Sorry champ
    And thanks mate, yeah went up a pass today and she went to the middle
    Thanks again champ Cheers for taking the time to describe it, much appreciated
    vn hsv sv enhanced
    Jan 2012
    brisbane
    Yeah mate wouldnt stress as jxw said its only the float rising and falling with the fuel and as for the heat 2nd bar is ok occasionally you will get a car that runs cold or someone might of just taken the thermostat out!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    you may also have a cracked solder joint or 2 in the voltage regulator in the cluster. If the gauges flat line from time to time or you have the tap the dash pad to get it working... it could be the voltage regulator
    and 3 Dangerous non ABS VN's
    VN Commodore Wagon
    Jan 2012
    Illawarra NSW
    Quote Originally Posted by hsv355 View Post
    Thanks Bud ! Yeah she got warm today as I said, going up the mountain, but yeah, As for the fuel, just trips me out sometimes
    And 88GreenVN, they don't completely flatline, but the fuel takes a while to finally reach it's level and tell you how much you have, but if you tap it , it goes straight up, otherwise it takes about a minute or two
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by BrokWoods View Post
    That tells me that it's probably cracked - but still making some contact.
    VN Commodore Wagon
    Jan 2012
    Illawarra NSW
    No worries, thanks for that bud !
    88GreenVN's Avatar
    Jun 2006
    I have a VP Calais International book in for next Sunday to fix the very same issue.
    VN Commodore Wagon
    Jan 2012
    Illawarra NSW
    Got an older brother who has had Commos all his life and as my description said , a dad with Monaros and mum with a Camaro (Shes not hands on though) So, getting it fixed should be not an issue....... (labour wise)
    Is it a hard job champ , do ya know?
    Thanks again for your advice and info bud, means alot
    88GreenVN's Avatar
    Jun 2006
    Cluster out, lens off and speedo out. Then you will be looking right at the voltage regulator. Pop that out and solder the joints again.
    about a 30 min job all up.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    Quote Originally Posted by 88GreenVN View Post
    30 mins if youve done it before.... carefully pry the voltage reg out though otherwise youll break the little clip and have to get out the super glue.... after 20 years everythings brittle....
    dont sweat the petty... pet the sweaty...
  1. VR Temperature & fuel gauge questions
    By iphitus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2010, 09:01 PM
  2. VP Fuel Economy and Temperature gauge :(
    By no idea in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2009, 08:58 PM
  3. VP Fuel Economy and Temperature gauge :(
    Last Post: 18-10-2008, 12:20 PM
  4. temperature gauge
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-01-2008, 11:46 PM
  5. Vt Temperature Gauge
    By stephen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 10:18 PM
