Results 1 to 3 of 3
Thread: Tail light loom
    VU II
    Aug 2007
    Bundy
    Question Tail light loom
    I've had a search but can't seem to find anything.
    Does anyone have a pin out diagram for the tail light loom (vp) and know how many volts each light should be?
    VP Exec
    Dec 2006
    Correct me if i'm wrong... But they should all be 12v. If you can't get a pin out get a multi meter and a set of alligator clips connect the black one to the chassis/ground and systematically go through the lights :-)
    Sent from my GT-I9100T using Tapatalk
    few commodores
    Feb 2011
    victoria
    12 volt system, 12 volt globes....
    only difference is the wattage
    21W ind, rev
    5/21W dual filament tail/stop
    you could get anything from 10 volts to 13 volts that far away from the battery depending on how good the wiring is in the rest of the car, i'd be guessing 10-11 volts with a car this age, youll get a different voltage if you use the body as an earth point instead of the neg terminal in the globe holder also, quite normal.
  1. Replies: 3
    Last Post: 12-01-2012, 11:51 AM
  2. [WA] vb-h tail wagon tail light and bumper
    By markovr in forum Swap / Wanted to Buy / Trade
    Last Post: 19-12-2008, 08:20 AM
  3. Wanted: VN tail light wiring loom
    By Cody in forum Swap / Wanted to Buy / Trade
    Last Post: 14-05-2006, 11:48 AM
  4. Tail light loom question
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-05-2006, 12:14 AM
