Results 1 to 16 of 16
Thread: pedders ultra lows.. not that low?
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    Default pedders ultra lows.. not that low?
    i just put my front ultra lows in my vn. put the back ones in a while ago. but when i put them in i was supprized it wasnt as low as i thought it would be. at the front end under the sill its about 14 cm to the ground and the back is about 16 cm. but looking at it for ultra lows they dont look that low.
    part numbers are 2129 for the rear
    and 2124 for the front if that helps
    vn calais 5.0
    Jun 2011
    victoria
    did you have the shoks and struts as well? How much lower is it from standard..
    1990 VN Executive
    Nov 2005
    I have a complete Pedders package in mine...If you measure from the bottom of the guards to the centre of the wheel I will measure mine for comparison..
    This is the best way to measure as it eliminates any variances such as different wheel and tyre sizes and even less air in tyres
    Dazz
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
    ve sv6
    Aug 2010
    pedders dont classify the coils as low, super low ect, but the 2124's are aprox super lows not ultras, there is a 2122 thats aprox 20mm lower than a 2124 but the ride will be crap due to it riding on the bump stops. the 2129 would be similar to a ultra low for the rear, and i dont think pedders have any thing lower.
    Sep 2011
    maryborough
    Quote Originally Posted by bj42turbo View Post
    Dazz
    its 35cm for the front and 30cm for the rear
    Sep 2011
    maryborough
    and no way would i get the 2122 springs mine sits front low already and i wanted it to sit flat :/
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by vn1989 View Post
    320mm rear 335mm front
    Dynamic Locksmiths
    Sep 2011
    maryborough
    does your car sit under 100 mm at the front because the lowest point of mine is just over 100 mm and yours is lower in the front than mine?
    1990 VN Executive
    Nov 2005
    I will check it for you....it better be though as When I took it in I said I want it as low as possible but keep it legal and safe
    sent from Dynamic Locksmiths Mobile using Tapatalk
    Dynamic Locksmiths
    1990 VN Executive
    Nov 2005
    Put up a side on pic of yours
    Dynamic Locksmiths
    Sep 2011
    maryborough
    there are 2 pics now very good quality and pritty small i had 2 compress them to upload them
    vn calais 5.0
    Jun 2011
    victoria
    Sep 2011
    maryborough
    i guess but for ultra lows i thought the back would be lower... im fairly happy with the front
    Sep 2011
    maryborough
    what does that peice of plastic do that hangs down under the front of the motor?? do i need it cause it sits under leagl hight its the only thing under 100 mm could i just trim it abit or take it off?
  15. #15
    1990 VN Executive
    Nov 2005
    Quote Originally Posted by mr calais 5.0 View Post
    that does look pretty low mate..
    Agreed that DOES look pretty low
    Dazz
    Dynamic Locksmiths
  16. #16
    Sep 2011
    maryborough
    dazz,
    did u get around to measuring the lowest point of yours?
  1. [VIC] FS: KING SPRINGS! Front super lows + rear ultra lows + monroe shocks all round
    By Patti2912 in forum Parts And Other Items For Sale
    Last Post: 10-04-2012, 01:27 PM
  2. [ACT] Pedders Sports ryder Ultra Lows
    By BADNWS in forum Parts And Other Items For Sale
    Last Post: 24-08-2011, 08:17 AM
  3. Pedders ultra lows and shock absorbers
    By mazrik in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2011, 03:21 PM
  4. Swap: super lows for ultra lows - VN sedan - in Perth
    By savage1987 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-08-2008, 12:47 PM
