Results 1 to 4 of 4
Thread: VN S1 anti theft module problem?
    VN S pack 3.8lt
    Jul 2009
    Unhappy VN S1 anti theft module problem?
    hey guys, A while back i bored out my 3.8lt and threw in a crow cam ect ect. When i fired it up the first time it ran fine until a few thing internally happened, so i had to take it out and fix a few minor issues. Once i put the engine in, my fuel pump will not prime but will run if it is bypassed and the injectors are not opening but have power. I have tried 3 engine harnesses and also fitted another body harness. Any ideas?
    I was doing research and found that the anti theft module cause's this to happen but is there any way to by pass the anti theft module?
    few commodores
    Feb 2011
    victoria
    check/replace your oil pressure sender, swapped relays around? not dirty/bad relay contact? fuel pump fuse isn't all corroded and making bad contact?
    does your car have the key switch in the glove box for security?
    VN S pack 3.8lt
    Jul 2009
    yea, all wires are correct, new fuse box / relay panel in the engine bay. but there is no key switch in the glove box??
    few commodores
    Feb 2011
    victoria
    what wiring loom have you put in? S1 or S2
    Engine light coming on when you turn to ignition?
    Here's a wiring diagram for 1990 but same area (top right of the schematic) to look if you're using earlier, check pin A6 on the ecu, is it +12V or 0ish
  1. VN Calais- Anti theft module
    By Mitch_calaisVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2008, 07:35 AM
  2. anti theft module
    By Matt_vp in forum Electrical Wiring / Questions
    Last Post: 15-04-2007, 08:13 AM
  3. Lpg Anti Theft Module
    By jake_au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2006, 08:29 PM
  4. Anti-Theft Measures
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 10:27 PM
  5. Anti-Theft
    By Lukie in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-05-2004, 03:45 PM
