Results 1 to 3 of 3
Thread: Check engine light after oil change on VP.
    vn4250 is offline vedelta
    VE Omega & VP Exec
    Sep 2005
    Wollongong NSW
    Default Check engine light after oil change on VP.
    After new oil change and new oil filter completed on my VP, now every time car starts shows a permanent check engine light. Tried diagnostics mode but keeps on flashing rapidly and no pause so can't make out if any codes being spit out. Also tried disconnect battery for 10 mins, still not fixed. The car drives fine even with the check engine light on???
    few commodores
    Feb 2011
    victoria
    unplug the ecu plugs and plug em back in 2 or 3 times, did you start the engine to check codes or just turn it to ign without the eng running?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Maybe you knocked a plug off somewhere? Look at the oil pressure sender near the oil filter.
    Visit my Facebook page
  1. Check oil light after oil change
    By fcm in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-01-2012, 10:56 AM
  2. Check engine light after plug change
    By holdenvtman1123 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-08-2011, 09:54 PM
  3. VE SV6 Check engine light
    By Melbsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-08-2011, 10:08 PM
  4. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
