I have a 1990 VN S1 S pack, I've taken out the engine and done alot of mods to it, but now im not getting pulse through my injectors and no fuel pump priming (works when bypassed). I have been reading around abit and the only thing i have come up upon is the Anti-Theft module. Does anyone here have any clue where it is on the vn, behind the dash somewhere?
Behind the dash, behind glovebox location, you should be able to gain access to it by removing the glovebox completely
I've removed the whole dash and the air con system and there is nothing in sight?!?! I've looked every where under the dash and there is no module in sight. Its got me confused :S
Not all vn have them only became standard in VP's vn calais got them standard if you dont have a bypass key in your glove box then you wont have one . VP's had them inside the passenger door when you open it
Originally Posted by Smidy
correct me if im wrong, but the vn's dont have an actual control module. its a mechanical lock barrel that just opens the fuel pump circuit... i dont think its linked to the bcm is it?
dont sweat the petty... pet the sweaty...
Check that the plug under the glovebox that connects the engine loom to the body loom is connected, its near the diagnostics plug. This has got me a few times.
The Daily VN T5V6
355 VN GRP A REP
