+ Reply to Thread
Results 1 to 6 of 6
Thread: wheel bearing access???
    VN-88's Avatar
    VN-88 is offline fiery red vn manual VN-88 Executive
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default wheel bearing access???
    hey guys, i wana check my rear wheel bearings, i got most of the way to them, undo my hand brake and the 4 inner nuts but i cant do anything else, it wont slide out... anyone got a pics showing all parts so i no wat they are, and steps on pulling it out... thanks
    vsII manual Guest
    You will probably have to hit it out with a soft head mallet. This is how i got mine out on my VS. Its pretty much te same set up, mines live axle not irs too.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok , but i aint sure ive undun everything, so i dont want to brake it... so i just need a parts photo, or the steps
    rattattack1313 Guest
    Cool
    OK..put the drum /disc back on, and only do up the wheelnuts 2 or 3 turns.....use it as a sliding hammer....the axle willl slide out..
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok rat so from the start i do this...
    1. take tyre off
    2. takr brake drum/caliper off
    3. undo hand brake pads and undo the 4 nuts
    4. put disk back on, slightly do wheel nuts up
    5. pull back and forth till she ocmes off... is that right????
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    well i manged to get the right hand bearing out, althought its not really noticeably damged, is there only the one bearing, on the wheel end of the shaft, cause mine only has the one, i hope one didnt get stuck in there,
    i did notice a few little fragments of metal on the shaft, but noting serious, i cant figure out were this wind is coming from
+ Reply to Thread
  1. Wheel Bearing Noise?
    By chromic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2007, 02:50 PM
  2. Wheel bearing price?
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2006, 05:59 PM
  3. wheel bearing plz reply
    By TheStateo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2006, 11:08 AM
  4. Wheel Bearing or Brake
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2005, 08:00 AM
  5. wheel bearing gone?
    By walace in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 10:42 PM
