Results 1 to 8 of 8
Thread: VP radio antenna
    VP Executive 5L
    Mar 2011
    Default VP radio antenna
    Got to get a new antenna cos the old one is busted.
    Are they specific to that car or can you get ones that will fit almost anything including them? I ask because the surface they go on is curved, not flat.
    vn calais 5.0
    Jun 2011
    victoria
    VP Executive 5L
    Mar 2011
    Today I cut the broken bit off and shoved a 3 foot length of welding rod about 1 foot down the guts and put a little plastic cap on top. All is well.
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    VP Executive 5L
    Mar 2011
    Mmmm.... s'okayish. I just listen to ABC AM talk radio. At low signal levels there is a little bit of ignition noise so I'll have to get onto that, but basically it's okay. I like listening to the car more than I do to the radio though.
    Feb 2011
    nowra, NSW
    interesting reply. I put up a question a while ago asking for assistance in dealing with interference (ignition noise?) while listening to radio national on the AM network. Didn't get much assistance other than suggestions that I get a better head unit. If you have any clues on improving AM reception then I am receptive to them.
    cheers
    VP Executive 5L
    Mar 2011
    Make sure:
    there is a condenser from coil + to engine (not body)
    engine is grounded to body via short, reasonably thick wire.
    bonnet is grounded to body same method
    plug wires and coil-to-dist wire run along metal surface of engine where possible rather than in mid-air
    antenna is attached tight to body rather than all loose like mine
    condenser from alternator output stud to alternator case to stop whiny sound.
    VP Executive 5L
    Mar 2011
    Also make sure plug wires are kept away from normal wiring loom to reduce sending noise into the whole show.
    Have seen some cars with an earthing strap from the radiator to body but that might be a corrosion (electrolysis) thing, but it couldn't hurt.
  1. radio antenna
    By tommykingsley in forum Electrical Wiring / Questions
    Last Post: 26-01-2012, 02:31 PM
  2. On glass UHF radio antenna. (Radio installers)
    By Stretchomatic in forum Electrical Wiring / Questions
    Last Post: 01-09-2011, 01:41 AM
  3. Connecting antenna wire to radio antenna
    By Denno in forum Electrical Wiring / Questions
    Last Post: 02-04-2010, 05:23 PM
  4. VS Radio Antenna
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 07:00 PM
  5. VT Radio Antenna
    By Hubba in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2006, 12:16 AM
