Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By wraith
  • 1 Post By GTP 85
Thread: Minispool skips worse turning right
    VX Berlina Wagon
    Oct 2007
    Default Minispool skips worse turning right
    Hey guys.. I put a minispool in my vp and I'm having a problem I think... When I turn right, it skips so bad that the whole car shudders.. But when I turn left, it skips a little, but hardly at all.. Both back tires are the same... Have I done something wrong?
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Welcome to minispools. You will find if you have lowered the car it will shift the diff to one side. That's probably half the reason.
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    I was thinking could a worn shock absorber cause this?
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
    VX Berlina Wagon
    Oct 2007
    I just noticed that my passenger axle is leaking, I tightened it as much as I can but still seems to be leaking a little.. Is there a certain way of installing them? Could that be the problem?
    VY Berlina V6 / R31 Skyline
    Dec 2008
    Of installing axles or mini spools? Is the axle leaking from around the hub? Could be seals, how long since you've done your bearings?
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    VX Berlina Wagon
    Oct 2007
    I'm talking about the axles.. It's leaking at the tire end.. I've never done the bearings, but in saying that, they aren't making any noises and they weren't leaking before I put the spool in..
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    something will be up with your suspension if it does that. What is the condition of the rear end bushes/ shocks?? I'm pretty sure ive made a comment in a spool thread before... that if you fit a spool all your bushes and shocks must be in new condition or else it will make all sorts of noises, and will drive weird. also they will tend to drive nicer and smoother on bigger rims i have found. on mine, 15s shudder like a mofo. 19's... beautiful!
    The leaking of the axle seal happens from time to time... some seals are no good one they have separated from the housing. Two options... Tightarse: buy another axle and bolt it in, hope for the best. Proper: pull the axle out and fit a new seal.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VX Berlina Wagon
    Oct 2007
    I've got another 2 sets In my garage.. I'll give them a bash..
    If I was to get one of those rear end bush upgrade kits, how long would they last with a spool?
    GTP 85's Avatar
    Aug 2006
    genuine rubber replacement will prob be the most forgiving, comfort wise. but may only last a few years.
    i have all nolathane. been like that for 3 years, no probs so far. but nolathane transfers more noise and vibes, and they are known to crack at times
    SS
    Jan 2012
    Australia
    Check panhard rod, have you got an adjustable one?
    Also get used to the skipping.. Thats the whole point of a minispool. Just get on the brake to turn right. simple
    VX Berlina Wagon
    Oct 2007
    SS
    Jan 2012
    Australia
    not too sure. if you didnt have one i would have suggested getting one.
    Just beat up on it more.
    I used to find that the wider the tyre - the less it would skip. But then i snapped axles... fun fun :|
    2002 VY Calais I V6.
    Jan 2011
    New South Wales
    Quote Originally Posted by King_berald View Post
    yeh it's adjustable.. Have I got it adjusted wrong?
    Spools/locker diffs, will always make some sort of shudder/tyre skidding around turns due to the fact that the gear sets are locked and moving as one. both rear wheels spin at different speeds when turning around corners, eg, inner spins faster/outer spins slower and vise-versa. so this is where ur getting ur shuddering. my mate has a vr with a welded diff. and it shudders like crazy on sharp turns due to the fact that both rear drive shafs are turning at exact same speed. not allowing one wheel to slow down for cornering.
    Considering A Manual Conversion!
    VE Berlina
    Feb 2010
    Melbourne, VIC
  15. #15
    VP Executive 5L
    Mar 2011
    That's a great vid alright.
    One thing they said though was the "low centre drive" aka hypoid diff that it was smoother and more rugged than a spiral bevel type. Not really true - trucks all use a spiral bevel diffs because there is less friction losses because less sliding motion between the teeth than a normal hypoid diff we all know and love.
  1. Does it get any worse???
    By Dr HaxZaw in forum The Pub
    Last Post: 05-05-2011, 09:47 AM
  2. indicator not turning off when turning corner
    By jared_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2009, 11:11 PM
  3. It's just getting worse...
    By Struma in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2008, 08:44 PM
  4. whats worse than...
    By `daj0pe in forum Jokes/Humour
    Last Post: 17-05-2006, 01:51 PM
  5. From bad to worse
    By TI0350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 10:20 AM
