G'day All,
How do I know if my VN has FE2 suspension?
see if it still has the build sheet under the carpet or pull the springs out and measure the free length
Jxw,
I think i'll look under the carpet, seems to be the easier option lol!!!! Just on that where abouts in the car under the carpets would the factory build sheet be?
Judging by the pics, it would have FE2.. Ground clearance on a VN with standard springs would challenge a Hilux
On the body plate next to SUSP, FE2 would be stamped.
There also other signs as slightly different swaybar size and spring tags with codes.
Where abouts under the carpet in the car Jxw? ie front/back/left/right hand side?
VNs are normally under the passenger's front carpet or under the passenger's seat.
LHF under the passenger feet i believe, just had another look, just in front of the passenger seat near the sill.. can only read the number and berlina on it though it's been pretty wet at some point.
