Results 1 to 4 of 4
Thread: Flywheel Help !
    Rb30
    Mar 2012
    San Remo
    Lightbulb Flywheel Help !
    I just got a VP, The last owner has snaped the flywheel bolts and has replaced all, But he couldnt get 2 out and die grinded them out, Is there any possible way to refread theam and fix them up, And having it running safely?
    Or would i have to replace the whole crank sharft?
    few commodores
    Feb 2011
    victoria
    recoil/helicoil thread repair kits, providing when the die grinder attacked it the holes aren't offset/out of round now.
    vp calais, vn calais, vp berlina all 3.8 litre
    Aug 2008
    Pascoe Vale South, MEL
    theres not enough to get an easy out in? so he just ground off what was sticking out? cause if thats the case you should be able to drill and easy out the remaining bolt....
    dont sweat the petty... pet the sweaty...
    VP executive sedan V6
    Feb 2011
    nowra, NSW
    On this subject the Gregory's manual and the Haynes manual have different methods of torquing the bolts up on the flywheel (for an auto, manual might be different) and I reckon the Gregory's is the go. I started to snap bolts with the Haynes method which gets expensive given the cost of $70 for a set of flywheel bolts. Gregory's says to torque to 18-22 Nm and then a further 70 degrees using an angle gauge. Easy to make up a gauge in cardboard that does the job. Haynes says torque to 75-90 Nm but the thread sealer I used acts as a lubricant and I felt the bolts snapping long before I got to those specs. My Gregory's is for a VP and my Haynes is for VR VS, My ride is a VP with a VR motor installed. Anyone else had similar experience?
  1. VX S V6 Manual - Dual Mass Flywheel or Standard Flywheel???
    By xeanerix20 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2013, 01:57 AM
  2. Flywheel
    By ecotec38 in forum Yella Terra
    Last Post: 28-08-2008, 02:15 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93
