Results 1 to 8 of 8
Thread: My VN keeps on stalling! Help!
    VN Berlina V6 3.8
    Nov 2005
    Exclamation My VN keeps on stalling! Help!
    I got vn v6. I got a chip off ebay and i installed it myself because it came with clear instructions. I had to place it in the Intake-air-temperture (IAT). It worked fine after i installed it for about a hour but later i started the car...it wants to stalled. If i get to a traffic light it wants to stall. So i removed the chip but its still the same. anyone know wat could be wrong. cheers!
    VP Executive R-spec
    Jan 2005
    VN Commodore S V6 series1
    Dec 2004
    im guessing pretty badly here but it sounds like the "chip" you put in was just a resistor that fools your car into thinking there is less or more air coming into the engine so it adds more fuel, take the chip thingo out and disconect your battery for like 10min and then try to run your car again see if resetting your ECU fixes your problem
    Commodores where do you want to go today
    vn executives
    Sep 2005
    Frd_thmsn Guest
    You got all the answers you needed in your duplicate post you did,the one titled
    "Map Senser".
    Map Senser
    I don,t see the need to duplicate your post .
    It couldn,t be a blatant attempt to get free press on these 20c resistors could it?
    Yes I,m a cynic
    If it doesn,t work give the guy negative feedback on ebay.
    But he,s too clever , he makes you give feedback before sending you the bonus information, that way he always gets positive feedback.
    How do I know ? I bought one ages ago
    vn executives
    Sep 2005
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I took the bellmouth out and it went harder, but the car was running good at start up and stuff, but when i installed CAI the engine likes to surge when slowing down like coming up to lights, ive reset the ECU by holding 3k RPM for 8 secs, no diference. Maybe when i get my chip from foamie it will help...
  1. VS almost stalling
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 01:07 PM
  2. Stalling VN
    By S Pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2006, 11:03 AM
  3. Car stalling
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2006, 01:25 PM
  4. Need help with stalling vs
    By Sandman240588 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2005, 11:28 AM
  5. vr stalling
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 01:55 PM
