Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By PROBLEM?
  • 1 Post By wraith
Thread: Wot are chaser wheels?
    VP Exec 5L BT1 ex cop, ex taxi
    Mar 2011
    Default Wot are chaser wheels?
    What are "chaser wheels" that people talk about from time to time. I imagine they are cop car wheels but what is different about them?
    Delish-VY is offline Banned
    2003 VY S pack
    Jan 2010
    Originally - Eastern Suburbs - Melbourne, Currently - Cairns
    DAKSTER's Avatar
    DAKSTER is offline Beam me up Scotty!
    VS Berlina
    Mar 2011
    Woodford QLD
    They also call them pursuits or interceptors. Its just a way of trying to make stock steel wheels sound cool, nothing special about them.
    Jul 2011
    Sydney NSW
    Cruze II sri
    Mar 2009
    Cairns White Rock
    Quote Originally Posted by HSV5L View Post
    The only differance is there silver with centre caps and 7 inch.
    I thought chasers and pursuits were different? I know Pursuits are 7'', but my local wrecker years ago was reffering to the standard steel rims as "Chasers" which were 15 x 6....Dunno maybe he was just using a bit of lingo to save breath.
    PROBLEM?'s Avatar
    PROBLEM? is offline umadbro?
    commo
    Apr 2012
    AUSTRALIA
    the bogan wheel of choice if your an absolute tight ass,people think they look good complete fools they are.
    SavVYute's Avatar
    SavVYute is online now Beatus ille
    VY S V6 Ute Series II 2004
    Nov 2009
    Duckburg
    Quote Originally Posted by PROBLEM? View Post
    Not so much 'good'. More like 'tough'.
    And they are a stronger wheel. They're fitted to cop cars for that reason.
    Everything has tizzy sparkly wheels these days....even prams.
    Me. I like chasers!
    Mar 2011
    Okay. At least one of my rims/wheels is black but the others are silver. They have the normal plastic 15 inch diameter cover but underneath some have the little plastic cap as well. Is ex cop car 110% certain. Back in the day I never could quite pick what made cop cars look different wheels-wise but now, duh.
    So then, are they the same width as standard or wider?
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    95 HSV Clubsport & 89 MX6 Turbo
    Sep 2008
    Demonicaland
    Chasers = 15x6 black rims often with hub cap
    Interceptors/Pursuits = 15x7 silver rims with centre cap
    VX Calais 5.7L & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    it will be written in the front of the rim down on the lip near the valve from memory, something like 6.00x15 for standard and 7.00x15 for interceptors/pursuits
    VN x2, VY SS ute
    Dec 2005
    S.A
    VL-VS BT1 also had 'stronger' silver 15x6 too. IIRC base model utes also used the same 6 inch rim.
    VP Exec
    Jun 2005
    Without getting into the semantics of chasers vs pursuit vs whatever, the wheels designed to have the silver centre caps are of slightly different design so as to retain the 'caps properly. This applies to ute rims also.
    In addition to the wheel dimensions, the offset is stamped into the rims and can be different for utes vs passenger cars, so watch for that if purchasing. For most Commodores you want 43P (43mm positive - the wheel mounting face is 43mm outboard of the wheel centreline).
    High strength wheels - used in VT- as standard fitment - are marked with an 'HS' stamping.
    EVIL304
    Oct 2011
    Well I think everone has covered this thread but they are called chasers because they do just that chase you.
    2005 VZ SS Ute
    Sep 2006
    Hey Cheap6
    Saw your post about the strength of steel wheels and hope you can give me some advise.
    I own a Holden VZ SS ute which is used solely for work - and when I say used for work, I mean it is worked hard with plenty of weight carried.
    About a year ago I had to replace one of the alloy wheels as it had a crack in it, and the same thing has happened again just last week.
    I am careful about parking against gutters (don't scrape the gutters), and can only guess that the alloy rims are not coping with crossing gutters or hitting bumps in the road when I am carrying materials on to work sites?
    I really am out-to-sea on this matter, but wonder if putting a set of the 'old steel wheels' on my ute might give me a stronger wheel to work with?
    Would appreciate your advice.
    Regards
    Logan
    Quote Originally Posted by Cheap6 View Post
  15. #15
    wraith's Avatar
    Sep 2008
    Demonicaland
    What rims are you currently using?
  1. Trouble fitting Chaser wheels and centre caps.
    By VjamesY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-10-2011, 11:09 PM
  2. wanted chaser wheels!!
    By mtharv in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-06-2011, 09:15 AM
  3. Interceptor/Chaser wheels
    By Bandito_Mac in forum General
    Last Post: 31-01-2010, 03:08 PM
  4. F.S: Set of 'Chaser' wheels
    By RebelSS in forum Parts And Other Items For Sale
    Last Post: 03-12-2007, 09:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
