Results 1 to 8 of 8
Thread: Help me with my vn troubles
    91 lexcen vn S2
    Nov 2005
    heathmont
    Exclamation Help me with my vn troubles
    hey guys. I have a vn lexceen series 2. i got it from my dad and i am fixing it back up so i can learn my l's on it and so i can **** around with mates. the only thing is, the interior is a bit messed around. The head(roof) linuing is off and there are no door seals, i pulled the plastic panels off and got the roof cardboard thingy off so i could pujt the new roof lining that i got from the wreckers on....what sort of glue should io use to stick it on..should i get some foam to replace all that orangy shit and then stick it on..or is it not going to make a difference. or should i just get some adhesive spray and stick it straight on.
    also..what other things should i do to get it up and running. and running well, what products or cheap mods should i get.
    your help is much appreciated........cheers
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    yeah well youd want to get either foam adhesive or normal spray glue and foam in between. me and vn_lexcen_s2 are working on it together, i god a air filter and he got a new mirror and roof lining fom the wreckers and a water peice and soem coolant from the shops and we are going to make it a good ride, we would have had a VP steering wheel but the wreckers guy kicked us out cos it was after closing time but yeah, what is your advise? foam adhesive???
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    have a search for mods to do after but for you head lining question the best way to do it is with some adheasive velcro. makes life easy if you ever want it out again and is relativly cheap but above all its easy.
    otherwise any adheasive with heat resistance will be fine.
    your post is a little confusing do you have an entire new cardboard section or just the material... if you just mean the material then get the proper foam stuff to back it to your old board
    91 lexcen vn S2
    Nov 2005
    heathmont
    yeh..i used the the old cardboard thing. i just took it out..where should i get that foam adhesive from..??
    thatnks for the quick reply
    YOU KNOW WHAT THEY SAY.......WAIT......NO I DONT
    manual VN aero
    May 2005
    SA
    not sure exactly but id start with holden and if they dont have it then apholstery stores will. just tell them what its for and they will be able to help
    minux's Avatar
    minux is offline Infidel Bear
    Mini Putt 2 Champion!
    Feb 2005
    91 lexcen vn S2
    Nov 2005
    heathmont
    i live in heathmont..which is in maroondah..which is in melbourne...how come???
    thanx for your help..its much appreciated for a 16 year old with not that much knowledge about the car world
    Sep 2005
    vic
    this looks pretty good to me, but yeah check holden first
    http://cgi.ebay.com/Acoustic-Foam-Sp...QQcmdZViewItem
    my web site
  1. Big Troubles..S.O.S
    By thechubybear in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2007, 06:50 PM
  2. vn troubles
    By william19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2007, 05:16 PM
  3. Car Troubles
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2006, 05:35 PM
  4. VH 253 troubles
    By Portunio in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-05-2006, 07:09 PM
  5. vn troubles
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 12:43 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
