+ Reply to Thread
Results 1 to 13 of 13
Thread: Wont shift to second!!
    sniperVN Guest
    Default Wont shift to second!!
    Hey people,
    Just recently my VN wagon refuses to shift into second (its auto)...
    Its like it skips it and goes straight to third, when i accelerate from standstill 1st revs right out to 50k's before it will change, and when it does it goes straight to third....
    If I approach traffic lights and shift down to 2 and accelerate a little theres nothing , like its in nuetral....
    Does this sound familiar to anyone? If it does what sorta price do u think im up for to fix it?
    Thanks
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You! STEALTHY™ W427 STEALTHY™ W427 STEALTHY™ W427
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Before you go out paying for a new box, try changing the fluid. No doubt if its never been changed, it'll be black. Try that, and if no luck, you wasted $20. Better than wasting 1000 for a new box if it could've been fixed by changing the fluid first.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    sniperVN Guest
    Hey thanks for the input but i just went and checked the dipstick for the trans and the colour was a medium brown colour!
    Any other suggestions?
    Anyone have a average price for a Vn auto box?
    thanks
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    sniperVN Guest
    Devil_CPJ Guest
    I would say that your second gear clutch is farqued....
    I lost third(and fourth) in the munro after towing a load that was prol to heavy.... when it shifted to third no drive at all..... just felt like neutral.... seems the same.... However strange that it will get to third... Change the gearbox......
    Lucky mate has gearbox shop and the fix was free.... Well almost I fixed his PC..... Love those bater deals....
    vh sle
    Jul 2005
    sydney
    yeah i had that problem in my VN. Changed the fluid and it was all good after that. Something like dextron 3 i think from memory. someone will tell you what fluid to use but hope to god it works.
    Sk00bS(fingers crossed)
    STEALTHY™'s Avatar
    Jan 2005
    Dextron III it is.
    And i have had that problem, hence why i sugggested what 'might' solve your problem. the fluid should be red, med brown means the fluid is dirty, and has every chance thats whats making the box play up.
    cheers sexy
    sniperVN Guest
    Thanks again for your help guys i suppose im changing some oil on the weekend
    VP 5Lt Calais
    Nov 2005
    there is a good chance that your 2nd gear solenoid has died on you and this will mean that u require a new box, there is a chance that the valvebody is stuffed and u can replace these for a couple of hundred bucks. best advice go to a tranny shop and get them to go on a road test with u they will give u an idea strait away
    VN Executive Series 2
    Oct 2005
    Failing that, recond. VN autos start from about $2100 fitted and go up from there unfortunately...
    Happened with me with the 3>4 clutch. Damn over-expensive overdrive automatics... I mean a recond. new trimatic would be like $800 installed...
    VP Executive R-spec
    Jan 2005
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by The90kwBeast
    hence why i changed my car to manual, cheaper, and lets face it, most peopel would rather a manual over a 'stock' recond auto.
    cheers sexy
+ Reply to Thread
  1. VR wont shift to 4th????
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 05:13 PM
  2. Has Anyone Got A Shift Kit In A Vy?
    By Egnitevt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-03-2007, 07:28 AM
  3. RIP Shift
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-12-2006, 05:40 PM
  4. shift kit
    By MRVPCalais in forum General
    Last Post: 26-09-2006, 02:21 PM
  5. VS wont shift into Park following work on stereo
    By catalyst55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 11:50 AM
