+ Reply to Thread
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By DAKSTER
  • 1 Post By GRPABT1
Thread: VL Holden Wheels wont fit on Trailer with Holden Hubs WTF?
    Jul 2005
    Default VL Holden Wheels wont fit on Trailer with Holden Hubs WTF?
    well trying to take my trailer for rego today the original tyres are pretty low an bro had a nice set of wheels to go on it but the stud pattern is slightly larger on the VL/VN wheels whats going on here?
    Devil_CPJ Guest
    VR Berlina V6
    Sep 2005
    orange
    Most trailers are "old holden pattern" ie torana, eh thru to ht. They changed at HQ.
    VS Acclaim S1
    Apr 2006
    I had a trailer built, asking them to match hubs with my VS. Clever boys put on Ford hubs which I have put up with as was given a spare. I have decided to change hubs to Commodore as the guys down at Bob Jane gave me some rims, however I will need a step by step guide or even some pictures. This site helped me change the ignition so hoping for help now.
    VS Acclaim S1
    Apr 2006
    Note to the last, (at the risk of being extremely obvious) I will be fitting hubs that take a VS wheel.
    VN SPAK
    Jan 2008
    commodore stud patten is 120 pcd
    whereis older holdens are 120.1 pcd
    thats if it is a 5 stud.
    Aug 2004
    Quote Originally Posted by vnskidder View Post
    drill slightly bigger hole :P Its only a trailer - done that already.
    AP
    VPCalais38's Avatar
    VPCalais38 is offline VP Sleeper VPCalais38 Executive
    93 VP V6 Calais Series II
    Nov 2005
    Geraldton, W.A
    The inside diameter of the hole in the middle of the rim is different as well.
    I remember fitting a VH rim to a HQ wagon. Everything kinda went together ok, but when it came time to remove the VH rim from the HQ we had to beat it off with a sledge hammer cause it was firmly wedged on the centre of the hub.
    They changed the hub centre and stud pattern from VB onwards as far as I was aware. As well as the obvious wheel offset.
    VE Omega sedan 3.0 2010
    Feb 2011
    Fly Creek, N.T.
    SunCoastSister wrote: "... I have decided to change hubs to Commodore as the guys down at Bob Jane gave me some rims, however I will need a step by step guide or even some pictures. "
    You will also have to make sure that the bearings match your new hubs. For some reason, a lot of people like to use Ford bearings, which are a different size from Holden bearings. If I recall correctly, you can mix and match the stud pattern with both types of bearings.
    See this page: Plain | Hubs | Hubs & Accessories | Products | Ark Corporation
    How to do it ? Basically, if you go to YouTube, and search on "how to change trailer bearings", you will find a dozen helpful 10-minute movies. Of course, you might not have to change your bearings, but instead of re-installing your old hubs, you'll be putting new ones on.
    VS Berlina
    Mar 2011
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden GRPABT1
    VN shitta
    Sep 2010
    The ville
    Pre HQ is actually 120.6
    Cheap, fast, reliable.....you only get to choose two.
    vn wagon cross fc wagon
    Jul 2011
    cambooya qld
    commodore wheels will not fit old holden hubs( ht or earlyer) or hq hubs the will break the stubs if you get them on to hq hubs. you need commodore hubs. try a trailer shop or wreckers for commodore hubs to go on the axles.
    VS Berlina
    Mar 2011
    You guys are aware this question was asked in 2005, revived by an archaeologist in 2008, then revived by another archaeoligist now? I'm guessing the OP has dealt with the problem by now...
    strgas's Avatar
    strgas is offline GRA = REAL HP strgas Berlina
    Oct 2009
    Quote Originally Posted by customholden View Post
    Grab a pair of old VB VP front disc's and a new set of bearings , check your axle diameters for correct ID of bearings. cheap and easy hub conversion.
+ Reply to Thread
  1. Replies: 14
    Last Post: 13-07-2008, 03:10 PM
  2. 16 inch holden wheels
    By nickdanger in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2007, 04:35 PM
  3. WTB: VZ calais wheels or other genuen holden wheels
    By commy92 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 05:08 PM
  4. WTB 17" Genuine Holden/HSV wheels
    By glassjowned in forum Swap / Wanted to Buy / Trade
    Last Post: 10-06-2006, 12:06 AM
