GRPAVL
- Jul 1, 2013
- 78
- 0
- 0
- Location
- Auckland, NZ
- Website
- homepages.ihug.co.nz
- 1987 VL Calais Walkinshaw
I found a few posts on here about the vn t700 trans's but no definitive answers. If i missed it please refer me to the post as it has surely been covered before.
I am throwing a vn 304/t700 into my VL commodore running the factory vl calais dash.
Pic 1/2/3
The factory drive appears to be an electronic setup to me which is no good for the VL Calais mechanical drive dash. I found one site that says to remove the sender (pics 1/2) leaving the drive itself (pic 3). I know my speedo cable wont reach the drive so I will need a new cable and found this somewhere on the net.
other option I was thinking of was is there an extension someone knows of that will convert etc. Dont wantto have to get the v6 conversion box is all.
Pic 4
also on the side of the box is a white 4 pin plug. I assume two are for the lockup and 2 for the reverse. Does anyone know which is which pin?
Regards
Q
Pic 1/2/3
Use a speedo cable borgwarner,2speed power glide To ht holden etc
Early t700 has same screw on backing nut as the powerglides and early borgwarner gear boxes
Pic 4
Regards
Q
