Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VN - VP Holden Commodore (1988 - 1993)
VN - VP Holden Commodore (1988 - 1993) Talk about anything relating to the VN - VP Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 19-12-2005, 07:56 PM
wes_v8's Avatar
WES_VN
Ride: 91 Vn Calais 3.8 Ltr
Trade Rating: (0)
wes_v8 Berlina
Angry trip computer
i know there is already a subject about the trip computer beeping but i'am having kinda a different problem.......ok when i first got the car it never used to beep.....but i had a tune up on it done and he took out the cluster to check the bulbs to see if they all work.......he put it back......Also i need a new ecu so he replaced that but now everytime i put the accelerator down it will beep at me and about 10 mins later if i haven't let go of the accelerator......it keeps beeping :b: it is getting really annoying. It won't beep any other time unless i put the accelleraor down everything else works on it.......any ideas?
__________________
If anyone wants to chat add me on msn
wes_v8@hotmail.com
Check Out My Ride Here: 91 VN Calais
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 19-12-2005, 11:07 PM
mouce's Avatar
Physics Geek
Ride: VN V6 Series 1 Executive Sedan
Trade Rating: (0)
mouce Executive
Tested for any fault codes? Maybe there is something going on that you should know about.
__________________
Gravity is proof that nature keeps getting us down.
  #3
Old 20-12-2005, 11:54 AM
wes_v8's Avatar
WES_VN
Trade Rating: (0)
wes_v8 Berlina
how do i do that?(test for fault codes)
__________________
wes_v8@hotmail.com
  #4
Old 20-12-2005, 12:11 PM
resident bush mechanic
Ride: manual VN aero
Trade Rating: (0)
HDT_aero Executive
get a paper clip or a bit of wire and find the empty plug belwo the glove box next to the left hand kick panel (if you cant find it it may be behind the kick panel but shouldnt be) now use the paper clip to bridge the black wire to the whit one....
they are both on the end of the plug now go turn your ignition on (dont start the car) and watch the engine light flash
it will flash pause then flash again the first flashes are 10's and the second flashes are units so if it goes flash flash flash pause flash flash that would be 32
each code will repeat three times and go to the next code if no codes are stored then it will flash code 12 repetedly
once all codes have been flashed it starts again so dont worry if you miss one
so go get us the numbers and we will see if anything needs replacing
__________________
im not admiring your car im looking in disgust
  #5
Old 20-12-2005, 12:12 PM
Trade Rating: (0)
HDT_aero Executive
i take it everything works on your cluster
does your handbrake light stay on when its down (that would cause a beeping from the trip comp)
__________________
  #6
Old 20-12-2005, 12:56 PM
wes_v8's Avatar
WES_VN
Trade Rating: (0)
wes_v8 Berlina
well im not sure because it doesn't have a bulb...........lol
__________________
wes_v8@hotmail.com
  #7
Old 20-12-2005, 01:00 PM
Trade Rating: (0)
HDT_aero Executive
lol swap a bulb over and check that cause that would cause the issue you described
__________________
  #8
Old 20-12-2005, 07:14 PM
wes_v8's Avatar
WES_VN
Trade Rating: (0)
wes_v8 Berlina
yeah but the light the guy swapped into the engine light was from the handbrake light.......would it do it if it had no bulb?(handbrake)
__________________
wes_v8@hotmail.com
  #9
Old 21-12-2005, 12:59 PM
Trade Rating: (0)
HDT_aero Executive
no it wouldnt effect it as the trip comp is wired up seperatly to the rest of the cluster
__________________
  #10
Old 25-12-2005, 10:13 PM
wes_v8's Avatar
WES_VN
Trade Rating: (0)
wes_v8 Berlina
ok then ill give the diagnostics test on it
__________________
wes_v8@hotmail.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Resetting your computer and trip computer special functions (VT - VX) Darren Holden Commodore How-To's 6 16-11-2007 10:19 PM
trip computer/total distance computer STOPPED! Juzzy21 VR - VS Holden Commodore (1993 - 1997) 5 31-01-2007 10:10 PM
trip computer???? cdawg VT - VX Holden Commodore (1997 - 2002) 4 15-04-2006 06:30 AM
VS Trip Computer Andrew Richards VR - VS Holden Commodore (1993 - 1997) 2 18-10-2005 12:00 PM
VS trip computer Berlina VS VR - VS Holden Commodore (1993 - 1997) 16 21-07-2005 01:39 PM
Loans | Mobile Phones | Remortgaging | Download Anime | Credit Card | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
