Results 1 to 15 of 15
Thread: Vn Idle Problem
    keatz_RedVN Guest
    Hey, ive got an 88 VN exec. auto and my motor wont start unless i give it some accelerater while turning the key, and once its on its ok when im reving but as soon as a take my foot of the accelerater it just stalls on idle.
    Does anyone have any suggestions to what the problem is
    Tony Guest
    not really sure, but with those symptons im guessing fuel injectors are gone?
    holden5l Guest
    Hi.Pull out the engine fuse. located in engine bay.For 15-20 sec. Replace fuse make sure air con is turned OFF start engine and rev engine to 3000 rpm approx and hold there for 10 sec. all should be reset and idle fine.
    keatz_RedVN Guest
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    what is a isu? this has got me stumped
    i am the god of britany spears womanizer on just dance on the wii
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    id say they mean icu
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    keatz_RedVN Guest
    OSL-060's Avatar
    OSL-060 is offline Banned
    Dec 2003
    SE QLD
    Shouldn't it be a IACV on a VN?- Idle Air Control Valve.
    ICU- Idle Control Unit? Mind you it's a decent acronym for the bugger, they do require intensive care when constantly getting covered in blow by.
    Nov 2003
    Hi there all,
    Mine also stalls sometimes when on idle, so that means my ICU might me faulty.
    Where is the ICU located??
    How do I check it???
    Regards,
    Arty
    keatz_RedVN Guest
    Since ive got my car fixed i seem to be going through fuel alot quicker , i reckon it'd be up to something like 15k/L, well thats what it feels like anyway
    keatz_RedVN Guest
    murri_rose Guest
    did u find out what icu is and where it is located i have the same problem
    VPower Guest
    darn EFI motors. a carbed would never have these starting problems (with a pull choke)
    but go the efi for its bit of extra power
  15. #15
    OSL-060's Avatar
    Dec 2003
    SE QLD
    Quote Originally Posted by murri_rose
    The mentioned ICU, is actually the IACV (Idle Air Control Valve), it's found on firewall side of the throttle body. If you remove the throttle body it's quite easy disassemble and clean, about 30mins max job. Doesn't hurt to get new throttle body gaskets either- less than $5 for both from Holden Genuine.
  1. VN V6 idle problem
    By Webster_140db in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2006, 11:04 PM
  2. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  3. Idle problem
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2005, 04:24 PM
  4. Idle problem
    By DISTURBED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2005, 09:26 PM
  5. Vn V6 Idle Problem
    By jackus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2003, 07:12 AM
