Results 1 to 2 of 2
Thread: 5.0l bellhousing bolt pattern = chev pattern?
    Mar 2004
    Default 5.0l bellhousing bolt pattern = chev pattern?
    Hi Guys, Can someone help me in regards to the bellhousing bolt pattern on a VN 5.0l block. Is it the same as the earlier 308 turbo blocks (chev pattern) or not? I am wanting to fit a T700 to a V6 Chev,I am hoping a 5.0l VN gearbox will bolt up. Thanks in advance.
    UNEMPLOYED????? HUNGRY?????? EAT YOUR IMPORTED CAR
    VP Executive R-spec
    Jan 2005
    Yes as far as I've read you can swap between the T350 T400 and T700 on a turbo patterned block. I guess the V6 chev would have ran a T350? so it should be a straight swap over, wouldn't it be cheaper to use the common V6 box ? what's different 1st gear?
  1. Wanted: Powerglide bellhousing w/ Chev pattern
    By maddog in forum Swap / Wanted to Buy / Trade
    Last Post: 17-06-2006, 11:18 AM
  2. VK 5 litre Trimatic bolt pattern
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2006, 09:09 PM
  3. 308 turbo pattern?
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-04-2006, 07:45 AM
  4. ~~~VP Stud Pattern?~~~
    By -**wHiStLe**- in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2006, 08:00 AM
  5. LS1 bolt pattern compared to small block chev
    By knight_mc in forum LSx Development and Modification
    Last Post: 26-08-2005, 07:56 PM
