The Central locking on my Vn just stopped working..any ideas? is it a fuse or something? every thing else seems OK
I got a similar problemif anyone can help. Central locking doesn't work on drivers door.
P.S. to enrico. What happens when you try to unlock? Just completley dead or what?
mine same but it only opens and closes the front doors replaced the battery still no go and only does sometimes
you need to lube your locking system and you may need to realign your actualors but once your inside the door it all becomes obvious
im not admiring your car im looking in disgust
how do you remove a central locking motor off your door anyway? i cant find the screws for it there hidden as one of my motors are jammed and avoiding me from locking the doors
my prob is the rear passenger side door..lock twitches but does not always lock then sometime will work for a week or two and die again
I have a problem with the central as well. Its like its not tellin the other actuators to lock. I lock drivers of course the drivers door locks but not the others heres what ive done so far..
Checked fuses everyting is fine Fuse 6- power door locks fuse 10 - Cent dr lck mod...--- ok nothin blown there
pulled door trim off Drivers door pulled out actuator and lock switch. The lock switch seems to be in working order...
i am conviced its the Central Controler or module is ###ed but hold on..
when i lock the drivers i can hear like a relay going off on the passenger side it maybe in the kick panel or dash, which leads me to believe its the central controller working but why is there no power getiing through to th other doors..
If i have overlooked something please let me know,..
And if you think i am Still sain let me know as im starting to get a bit insanly pissed atm
any help will be appreciated ,
thanks in advance...
Redski
