Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: VN struts
  1. #26
    wes_v8's Avatar
    wes_v8 is offline WES_VN
    04 Vz Sv6 6 speed
    Jun 2005
    Maitland near Newcaslte N.S.W
    yeah anyone one with pics of bonnet and boot struts would be good
  2. #27
    Madhouse_Dave's Avatar
    Madhouse_Dave is offline Crazy but Happy
    Vt Berlina Sedan & VT Excutive Wagon
    May 2005
    Cool
    Hi All
    I changed my VN wagon over to bonnet struts. I grabbed the nuts and bolts and the struts from the wreckers off a Vp and just screwed the main ball mounts in place. they charged me $25 for the pair. Dont forget to get the flat bolts that sit in the gaurds or you may end up with a bent bonnet. These sit in the tops of the gaurds where the struts lay in the tops of the gaurds. also they let everything sit down far enough for the bonnet to shut correctly. I would say it took me about 15mins a side to do with the gaurd flat bolts and then once all those were in I just lifted the bonnet off the old steal stick and pushed on the struts.
    dead easy and after another trip the wreckers I was helping others change theres it made a few VN Owner very pleased :-)
    If You get stuck for Pics either look at a VP or I will drop you some Pics of My VN conversion no worries
    I've Got Papers To Prove I'm Sane.
    Can You Produce Some Too ???
    Madhouse_Dave
  3. #28
    wes_v8's Avatar
    04 Vz Sv6 6 speed
    Jun 2005
  4. #29
    May 2005
    Cool
    Hi All
    its Dark out but I will go take some and post shortly.
    See how they turn out.
    They turned out Ok but I have resized them they seem to small to me.
    If anyone would like bigger pics I will email them if you would like..
    Madhouse_Dave
  5. #30
    wes_v8's Avatar
    04 Vz Sv6 6 speed
    Jun 2005
  6. #31
    vn4play Guest
    damn you beat me to it!! i had a hard time getting the nuts on the top ball pins it was a mission to keep a nut at the right angle under the bonnet skin. took me about 45mins all up after having to use my faithfull magnetic tip grabber tool to retrieve the dropped nuts. also i seem to have installed my struts upside down not an issue though just pop the clip and rotate it. also i did not have to change any bolts and my struts and bonnet sit perfect maybe i found a home mod cause my bottem bits are around the wrong way too and nothing fouls? anyway here is some pics of mine seeing as though i promised i would post em
    cheers jimbo
    Attached Thumbnails Attached Thumbnails VN struts-engine_strutssmall.jpg   VN struts-rightbottstrutsmall.jpg   VN struts-righttopstrutsmall.jpg
  7. #32
    May 2005
    Cool
    Hi Again
    The only reason I mentioned the flat bolts you see in my pictures was all the Vps and up I saw had them so I made sure I changed them. most of the VN bonnets I saw had the bolt holes in the bonnet already but I know what you mean about the holding the nuts inside the bonnet Skin.
    Im in Sydney out in Blacktown and if any members would like a hand doing this to there Vns I and free most days. Feel free to give me a PM or email and we can arrange something. I dont mind helping and have a great wreckers close by if anything is needed.
    Madhouse_Dave
  8. #33
    wes_v8's Avatar
    04 Vz Sv6 6 speed
    Jun 2005
  9. #34
    1991 VN Commodore, 1997 VS Statesman II V8
    Jun 2005
    Might be a good idead to ask some of the VR/VS people for pics, im pretty sure they came stock and the setup with the struts would be the same.
  10. #35
    May 2005
    Cool
    Hi All
    I have a mate with a VR sedan I will ask him If
    I can take a few pictures. I asked the guy at
    the wreckers but they say no Pictures to be
    taken inside the yard. Funny that theres nothing
    but wrecks around. I guess they are worried about
    being Sued. I just wanted to take a few Pics so I
    could compare some things. No Camera phones also
    but I dont know how they can check everyone for them :-)
    Madhouse_Dave
  11. #36
    Jun 2005
    I had a look today at the wreckers and found a pair of mint condition boot struts off a VS lexcen. The prob is where and how do i mount them? the fount end of the struts is connected by a piece of metal with a ball joint. The other end is attacted with another ball joint in a bolt sort of thing. I noticed on the VR/VSs there isnt that big piece of metal running up the side behind the arms. It has a lot of holds in it to put in a ball joint. Id imagine id have to remove the old rods. Can i get ball joins from any hardware shops that i can bolt on?
  12. #37
    May 2005
    Cool
    Hi thats good to know
    I think you can check the ball joints on the VP bonnets and the VN to VS
    Tail gates. these maybe the same and then you could collect 4 and test the
    struts. Please make sure you be carefull and post your findings. I have a wagon but this still interests me. You may need to find some nuts to bolt them in but im sure you are a clever person and will find a good solution.
    Madhouse_Dave
  13. #38
    VN Commodore
    Feb 2006
    if ya want some struts look on ebay for them.. they go from time to time.. when people wreck cars... get some good second hand ones...
  14. #39
    wes_v8's Avatar
    04 Vz Sv6 6 speed
    Jun 2005
    yeah i installed sum 2day in my car anyone got pics of boot struts or can take sum pics?
  15. #40
    ProMaX's Avatar
    ProMaX is offline Make way!
    04 VZ SS Impulse Blue Ute
    Aug 2005
    Bella Vista, Sydney
    hey madhouse dave could u help me install my bonnet struts? i live in castle hill ^_^
    Never Forget You're Unique... Just Like Everyone Else
    I'd Rather Roar Than Whistle
  16. #41
    May 2005
    Cool
    Howdy all
    Hi Promax just reply to my PM and we can organise a time and date to
    install your Bonnet Struts. No worries. Im in Blacktown not far away.
    Madhouse_Dave
    Madhouse_Dave
  1. Do VT struts fit a VS?
    By martinarmstrong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 06:17 PM
  2. anyone used air struts before?
    By vrmica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2006, 08:55 AM
  3. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
  4. Vr /vs Struts
    By RVN 355 in forum Swap / Wanted to Buy / Trade
    Last Post: 06-11-2005, 11:54 AM
  5. VR/VS Struts into a VN
    By mechanic22 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:29 PM
