I am looking at buying an eaton M90 supercharger.
I am going to put it onto my VQ 5.0L .
What will I need to get this onto my car, and approximately how much will it cost?
Thanks
hey man, i was thinking bout doing the same thing to my vq 5ltr, with the same supercharger (m90)!!!!!!!! if ya get any info 2 your questions can you pleez let me no!!
thanx
As far as i know the eaton m90 would not have enough displacement for a v8. But correct me if i am wrong! You better option would be the bigger m112 eaton supercharger, the same as the one that yella terra uses.
i read that they are good for 3.0 to 5.7 litres.
i just want to know if anyone knows how where and how much to get the manifold custom made so i can top mount it
have to agree with VN Calais 5.0. a mate has one on his VN V6(VX motor) with an M90, and apparently thats tiny even for the 6.
Originally Posted by davway
Yella Terra use an M90 supercharger for their kit.. Here are some links that have some info on the M90 (Terra Charger) and the M112 (Marks Workshop).
The M112 is the better choice for the Holden 5.0 litre. Also check out Eatons Website for some development history and application for these blowers..
http://www.yellaterra.com.au/kits.php
http://www.marksworkshop.com.au/Pages/mws.htm
http://www.automotive.eaton.com/prod...gers/index.asp
the eaton m90 is the same super charge used on the factory supercharged 3.8
info
http://www.capa.com.au/eaton_m90data.htm
pricing
http://www.capa.com.au/prices_eaton...._superchargers
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
intresting $2789.00 for a super charger...(v6 i assume) not bad (plus pulley aswell)
Probbly work out to 3k, how much kw gain could you expect to get on say a 125kw buick v6 (89) or when it refers to 3.8L v6 does it mean the supercharged vt version?
No..I'd reckon that price is for the supercharger only, you would also need an inlet manifold,drive extension, idler pulleys, belt, upgraded injectors,modified inlet to feed the blower at the rear of the motor, chip re-tune. An Eaton supercharger kit for a V6 is what you're looking for and CAPA don't do one. You'd be better off buying a factory supercharged V6...Originally Posted by 1337PaRaDoX
