Results 1 to 7 of 7
Thread: BOSS KITS which one?
    610 is offline
    VG UTE
    Mar 2005
    Default BOSS KITS which one?
    Just brought a second hand Saas wheel. It comes with a boss kit.
    When I picked it up the lady said she "think" it came of a VL. I was wondering if that boss kit would fit to a VG (VN) ute.
    And is there any way I can tell what sort of boss kit it is. Ie any serial numbers or anything?
    Just dont want to pull my other wheel of and be left with a nub to steer with.
    Thanks
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Im not certain, but i think the boss kit was vb - vl and vn to vs, just pull it all off and try it, takes 5 mins
    vn4play Guest
    i don't think they have any serial numbers on them, i could be wrong though. If you can't find any id numbers on it you may just have to pull your old wheel off and try the new one, if it does not fit just put your old one back on. its not a hard job just loosen the nut and start pulling(don't take the nut off if you don't want to get smashed in the face or ribs by the wheel).
    jimbo
    610 is offline
    VG UTE
    Mar 2005
    It has two boss kits. They both look the same.
    But one is of a VL and the other is of a ZD-ZC fairlane.
    So guess I will be reselling both.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by minux
    Yes that is correct.
    AirStrike
    Selling FG G6E Turbo and buying a N/A Supra
    610 is offline
    VG UTE
    Mar 2005
    So theres no way I can modify the VL and to suit a VN then?
    Do you know where and how they different.
    vn4play Guest
    at $50-70 i would not modify one as it is a key part to the steering and imagine it coming off at speed(not good). it would be the offset and the spline thats different.
    jimbo
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. Boss Kits (SAAS and Autotechica)
    By veclubby in forum General
    Last Post: 26-12-2009, 06:57 PM
  3. Boss Kits
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2007, 06:11 PM
  4. Is CA Boss the same as effects Boss?
    By semi in forum Car Audio
    Last Post: 08-01-2006, 02:30 AM
  5. autotechnica boss kits
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2005, 09:22 PM
