Results 1 to 4 of 4
Thread: ignition barrel
    ssmartie2001 Guest
    Default ignition barrel
    Can anyone tell me how to remove the ignition barrel in my VN the existing barrel is shot and I purchased a new barrel the goose at the part suppliers said it was a simple procedure but I'm not so sure.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    you need to be able to turn the key and push a pin in the release hole
    if you cant turn the key then go nuts at it with a big screwdriver untill you can turn it
    im not admiring your car im looking in disgust
    redcedar's Avatar
    redcedar is offline workaholic
    Alto Grey MY12 SS
    Nov 2005
    coffs harbour
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    (the following comes from the Gregorys manual):
    1) Disconnect the negative battery terminal
    2) Twist the fuse panel cover retaining clips 90 degrees and allow the cover to swing down,
    3) Loosen the lower steering column cover retaining srews and remove the lower steering column cover from the vehicle.
    4) Insert the ignition key into the lock cylinder and turn the key to the 'On' position.
    5) Insert a 3mm wire into the locking pin hole and depress the locking latch. Withdraw the lock cylinder from the steering column.
    6) Disconnect the wiring harness connector from the ignition switch
    7) Using a small bladed screwdriver remove the ignition switch retaining screws. Withdraw the switch from the steering column.
    Installation is a reversal of the removal procedure with attention to the following points:
    1) When installing the lock cylinder ensure that the ignition key is in the 'On' position
    2) When installing the ignition switch ensure that the slot in the switch aligns with the stepped end of the lock cylinder shaft.
    That should help.
    Gravity is proof that nature keeps getting us down.
  1. Ignition Barrel
    By vt com in forum General
    Last Post: 01-01-2008, 02:10 PM
  2. ignition barrel
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 07:26 PM
  3. Ignition Barrel
    By StillDreaming in forum General
    Last Post: 24-09-2007, 04:25 PM
  4. Ignition Barrel
    By Not_An_Abba_Fan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2007, 12:13 AM
  5. Ignition Barrel
    By jonathon_86 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2006, 02:01 PM
