Results 1 to 13 of 13
Thread: VN door skins - Removal help..
    VL
    Jul 2005
    SA, Mount Gambier
    Default VN door skins - Removal help..
    Hey fellas I need for remove my door skins and im wondering how i do that? and any tricks to take off the winder??
    Also I have some 6" splits and crossovers here ready for installation. Is there any hole in the actual door for the speaker to fit? with out using pods or VR/VS door skins.
    Boonz's Avatar
    Boonz is offline Donating Member
    green 355 VG ute
    Jul 2005
    berri, south australia
    dont put holes in your doors.....they flex under pressure so get a set of pods or something to house those speakers and crossovers
    VL
    Jul 2005
    SA, Mount Gambier
    ok... any howto on howto remove the door skins?, i would like my installation to be pain free.
    Jun 2005
    door trims arent too hard to remove. you gotta use a special tool, or else a flat head screwdriver, to get the window winder handle off. there is a little metal clip in it that holds it to the door.
    after that, you gotta use the screwdriver to remove the plastic cover on the interior door handle. under that there are 2 screws to remove. you also have to use the flat head to get the orange clip out of the door lock. remove it and there is a screw holding it onto the door.then after that, you basically pull it off around the edges.
    here is a slighty more detailed description for the winder -
    if you dont have the tool, get a small flat head screwdriver. pull the winder back away from the door as much as you can until you can see a small metal clip. push on the clip with the screwdriver, and it will eventaully come out. make sure you have a cloth or something on the other side, because those metal clips will shoot away if youre not careful.
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VL
    Jul 2005
    SA, Mount Gambier
    Jun 2005
    if you need a picture to help understand, let me know
    VL
    Jul 2005
    SA, Mount Gambier
    Jun 2005
    email has been sent
    VL
    Jul 2005
    SA, Mount Gambier
    warney's Avatar
    warney is offline did you say bukakki party
    VL skid car what else are they built to do
    Mar 2005
    OK if the screw driver is no good try and old t shirt of tea towl stretch it out under the winder and push it upwards to it pushes the clip out ...
    make sure it dosnt fly off though !!!
    VS commodore series 2
    Sep 2005
    northen suburbs/vic
    i find 2 screwdrivers works best, the first one u use for leavage and the bigger the better then just pops off
    VP
    Sep 2005
    man when i was undo'ing my door the first time that was a big trip, then when i got that, getting the actual lock off was a b!tch .
    VP Executive R-spec
    Jan 2005
    Just got another lock from the wreckers today, sounds like I'm in for some fun
  1. door handle removal
    By kyl'svs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-09-2006, 11:55 PM
  2. Door Skins, customise or not?
    By Daniel Gray in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2006, 08:50 PM
  3. vz door skins?
    By allblak in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-07-2006, 04:55 PM
  4. VB-VL Door removal
    By VHSLE5LTR in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-01-2006, 06:17 PM
  5. Front Speaker change... door skins off??
    By Roman54 in forum Car Audio
    Last Post: 06-10-2005, 07:05 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
