Results 1 to 9 of 9
Thread: Make a VN-P run ALOT cooler
    VPower Guest
    Default Make a VN-P run ALOT cooler
    just thought i'd post this up to see if this may help someone.........
    the previous owner of my VP had the radiator sh!t itself after he had it for 4 months. he got a VT radiator (from the wreckers, which not only works that bit harder, it doesn't stick out at all below the front bar which is GREAT for reversing out from driveways with big curbs) and a few months before i bought it, he had to replace his H20 pump (apparently a bit of a fault on the HEC3800). with a new water pump and VT radiator she runs colder and a bit smoother as well.
    the temperature gauge is almost always on 'C' the whole time (perhaps a bit above with a bit of rev)
    only problem is getting a VT radiator 2nd hand from a rear wreck or a project car (or just buy a new one if you have the money)
    hope this helps someone..............
    Ute God Guest
    having your car running on C all the time is that good.....you will notice that the fuel consumption will go up, and it can have other side effects
    VE Berlina International II
    Nov 2003
    hmmmm interesting, might have a look in to that, not that expensive??
    Thats all right, thats ok, I drive a commodore anyway!!!!
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Is this on a V6 or a V8? I have a V6 and have never had it over about 1/4.
    VPower Guest
    it's a 6.
    even with my mate (when he owned it) pushing it ALOT it rose to a tiny bit below about 1/2 way. and that was it.
    as for price, a 2nd hand one was claimed on a $50 pick-a-part (wreckers yard 'promo') the new water pump was about $200
    MaNiac_VP is offline Mr Moderator !
    VPII Calais
    Oct 2003
    As long as your oil reaches normal operating temperature, and your heater works fine once the car is warmed up, then the car should be a ok. U will know if your oil isnt working fine as it will sludge up soon.
    The VT radiator is made for a very similar engine, so therefore it should work within the tolerances made by the engine.
    VPower Guest
    it makes a perfect fit. afterall, it is a newer version of the same radiator, just a bit thicker and doesn't poke out underneath the front bar. the VT bay is pretty much exactly the same as the VN-VZ commodore
    OSL-060's Avatar
    OSL-060 is offline Banned
    Dec 2003
    SE QLD
    Quote Originally Posted by VPower
    The radiator support (actual structual piece of the car) is below the radiator. All that hangs below the front bar is the plastic stone guard/cowling. Which can be removed if it scrapes or you don't like the look of it.
    VPower Guest
    my VT radiator has that on it and still doesn't poke out underneath. which is good
  1. Speedo out by ALOT!!! since GB Chagne
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2011, 06:06 PM
  2. Dumb mistakes cost alot.
    By Jasoniumh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-12-2007, 10:57 PM
  3. Blowing alot of condensation at time
    By jonathanvb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2007, 07:47 AM
  4. blowing alot of headlights
    By BANKS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-10-2007, 12:35 PM
  5. i want to do up me commo, but i dnt have alot of money. What can i do?
    By bundy bear in forum V6 Development And Modification
    Last Post: 11-06-2006, 12:33 AM
