Results 1 to 6 of 6
Thread: strong fuel odour. help?
    VN series III & Honda VTR250
    May 2005
    sydney
    Default strong fuel odour. help?
    any help on these would be hugly appreciated. i really dont want to have fork out for a trip to the mechanics at the moment.
    1/ theres a strong fuel odour coming from underneath the drivers door, i cant see any leaks around the lines, all the hoses seem in good repiar. there isnt realy a smell from the exhaust or the engine bay. the O2 sensor is pretty new. the exhaust smell is pretty foul too. code 34 was showing up, but i tested the MAP with a multimeter and all the correct values seemed to be coming out city driving fuel economy about the same, freeway fuel economy has gone down the shitter.
    2/ loud whirring noise from front L/H wheel, pretty sure its the bearings, but the hub seems secure, the noise starts at speeds over 80ks
    3/loud metalic clicking noise from the heads down towards the rear of the engine, not the front, it goes away after the engines been running a while, or if you pump the accelorator quickly.
    once again any help on any of these problems would extremly helpful.
    cheers
    CBR954RR
    XR400R
    dont knock riceburners, they are fast and reliable...
    rare and endanged 94 VR auto white sedan
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    I would be looking underneath my driver's side back wheel arch where your filler pipe to your fuel tank is. You should notice a heap of breather hoses there. I say these are your culprits. Now to do them properly you need to take the fuel tank out. Or to get yourself out of trouble for now, just get an inline joiner (probably need two) and cut the broken sections and join up a good piece of fuel line up. But after time the hose will break again further down the line.
    Open your bonnect check every injector where they go into the inlet manifold. Check all fuel hoses as well.
    Sometimes a fuel smell can be somewhere different from where you can first smell it.
    That sounds like bearing noise, but they might not be bad enough to fell anything different yet. Only way to tell is to unbolt your wheel then unbolt the brake caliber assembly, then turn the wheel hub around. To see if you can hear the bearing then.
    That loud clicking noise could be lifter/tappet noise.
    Yours Kindly,
    Jim
    May 1991 VN Wagon V6 Auto
    Jan 2006
    Clicking noise - Check oil level/quality
    Fuel smell - Like Jim says, check breather hoses (I had strong fuel smell from engine bay little while back. Ends up mechanic replaced high pressure fuel line with smaller outer diameter hose, but used same hose clamp. Didn't tighten completely an p!ssed fuel into the cavities on the inlet manifold, filled them up completely. Still don't know how the thing didn't catch fire.)
    Bearing noise - Also suggest check tyres for uneven wear/scalloping.
    Noise elimination I call it. Find noise, eliminate it. That's all I ever seem to be doing.
    VP Executive R-spec
    Jan 2005
    I think number 3 and your smell is a cracked header and stops making the noise once it's hot and joined back together with heat expansion
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by iwishmyVNwouldstart
    cheers
    #3 fault.....is it manual or auto?if it's auto i'd say your flex plate is cracked,by the noise you have described.
    Sep 2005
    i've got a link to some info on that one, not too sure but i think its for an 8...
    http://www.users.on.net/~nweber/commodore/tech/
    catch
  1. Strong foul odour coming from A/C
    By hothousegreen in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-02-2007, 06:38 PM
  2. vs v8 manual strong?
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 12:24 PM
  3. Strong fuel smell from engine bay.
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-04-2006, 09:58 PM
  4. be strong honey
    By bazcom in forum Jokes/Humour
    Last Post: 24-03-2006, 09:12 PM
  5. Strong Bad!!!
    By INSINR8R in forum Jokes/Humour
    Last Post: 09-03-2006, 11:17 AM
