VN_SS_CM
Hey Guys,
I have a height issue with my clutch pedal and I have since replaced the clutch cable with no luck! Currently I have wound the threaded part of the cable at the bellhousing end right out to the end and the pedal sits about 8 cms from the floor....I replaced the clutch, pressure place and flywheel(billet yella terra) about 2 years ago and was able to get it adjusted to factory specs and the thread part at the bellhousing had heaps of thread left for adjustment now for some reason its wound all the way out what could be causing this? the clutch pedal is still good no slippage at all but I do get some shudder in reverse.
cheers guys
cheers guys
