Results 1 to 7 of 7
Thread: Removing the Vacuum Block from the heater controls?
    ProggerPete Guest
    Default Removing the Vacuum Block from the heater controls?
    Hi guys, still trying to get the heater unit out. The problem now is the vacuum hoses attached to the heater unit.
    How hard should I pull on the hose when trying to ge them off?
    Is there any tricks to getting them off?
    Do they come off as a block or individually?
    kowan's Avatar
    kowan is offline Clayton's Commodore
    91 Clayton's Commodore/Toyota Lexcen
    Sep 2005
    Far North QLD
    Just lever it gently with a screw driver or pull it out gently
    http://aussiewholesalers.com now closed When I growup I`m gunna buy a real car
    '97 VT Calais 5.0
    Jun 2005
    Taylors Lakes
    getting them off is the easy part, getting them back on without a minor leak is the fun bit!
    ProggerPete Guest
    '97 VT Calais 5.0
    Jun 2005
    Taylors Lakes
    they are a c**nt of a think to put back in sometimes, VN especially. lucky with the VP its a different block and has little guides to help you slide it in gently
    best bet is to line it up and put a screwdriver through the hoses (not literally) and push the block back in to the heater unit... you could use your fingers, but i doubt any one has fingers that small.
    hope ive been helpful in some way!
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Using the screwdriver to lever it on/off is the easiest way in the VN. Just make sure that none of your vac hoses are bent/twisted/kinked/caught when you put the entire assembly back in, otherwise you're going to have at least one position that you can't get to. Once you've done it once it's really easy to do it again, but that first time while you're working things out can be a real headf**k.
    Gravity is proof that nature keeps getting us down.
    '97 VT Calais 5.0
    Jun 2005
    Taylors Lakes
    yeah, the first time i did it, the hose for the vac hot water cut off came loose and the noise was pissing me off for some time till i worked out what it was!
  1. VP Calais Heater vacuum
    By vsuterus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2011, 11:58 AM
  2. Removing AC/Heater controls
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 02:00 PM
  3. Vk Heater Controls
    By lairdy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-06-2005, 01:21 PM
  4. VP Heater Vacuum
    By syncope in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 07:43 PM
  5. No Vacuum at the heater tap
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2004, 02:27 AM
