Results 1 to 12 of 12
Thread: why won't my car start when its hot
    murri_rose Guest
    Default why won't my car start when its hot
    You most likly have heard all of this before I tried to go back in the forum and find a simular problem but there are too many. I have a vn 1989 and have this problem it seems to happen when the car is hot I can drive it and then when I go to get back in it won't start (won't kick over) it happen once and this gentleman said pour cold water over the injectors which he did for about 3 minutes and it started I have taken it to a garage and they can't seem to find the problem. Also petrol comes out through the injectors not all of them just about 2 of them
    would love to hear any advice
    Dezza's Avatar
    Dezza is offline your local HSV dealer
    Cammed up Vy Clubby
    Feb 2004
    sounds lik eu got leaky injectors maybe time for some new ones if its the injectors leaking i cant see how a mechanic would miss that though
    VN
    Nov 2005
    I had the same problem, it was the crank angle sensor that was causing my problem not the injectors.
    vp executive wagon
    Feb 2005
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    vp executive wagon
    Feb 2005
    yeah, cold water on the CAS always workd for me until I had tha CAS replaced no problems since.
    VR Acclaim S2
    Feb 2005
    viewbank
    definately your crank angle sensor it is so common but if your injectors are leaking get new o rings and you might aswell get them cleaned and flow tested whilst they are out.
    murri_rose Guest
    bruised Guest
    gocommygo Guest
    VN Commodore
    Feb 2006
    i am going to say the same as everyone else... crank angle sensor on mine too.. bloody things why do they sh*t themselves so much..
    murri_rose Guest
    Quote Originally Posted by murri_rose
    I did one of those code fault finders and it showed up number 23 Mass Air Temp Sensor would anyone be able to give me a clue on what that is and where is it and how to fix it. I think this maybe the reason for the not starting when its hot.
  1. When VN S2 Start?
    By pro_gmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 05:01 PM
  2. Help, VS won't start
    By Matilda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 08:34 PM
  3. Didn't Want To Start
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 03:14 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
