Results 1 to 11 of 11
Thread: Battery light goes on and off
    ProggerPete Guest
    Default Battery light goes on and off
    Hi all,
    On my VN Commodore the battery light occassionally comes on. It isn't on for long, usually not more than a minute or so. The battery is about 18 months old. My query is whether anything other than low battery charge can cause the battery light to come on. ie. could it be a problem with the alternator or something else.
    Doesn't seem to be causing any problems, I just don't like red lights coming up on my dashboard.
    VP Exec,honda civic,mazda626
    Jan 2006
    watsonia
    michaelw's Avatar
    michaelw is offline Donating Member
    VX S2
    May 2005
    Newcastle NSW
    I'd put money on the regulator on the alternator. It is the black plastic bit on the alternator. It has brushes that attach to the slip rings. Do a search on this site for 'regulator'. They cost about $50.
    Mike
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I reckon michaelw is spot on - the brushes wear down so they no longer make contact with the sliprings. You can solder new brushes in but the easiest is to buy the regulator with brushes - just costs more. Probably don't even need to remove the alternator to remove the 2 screws holding it in.
    jdd
    jdd is offline
    Jul 2004
    More than likely it will be the regulator itself, not the bushes.
    It’s very common for them to fail in the manner described.
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    i'm having the same problem so looks like regulator? cool at least thats cheaper than alternator.
    cd1
    cd1 is offline
    vn 5.0L
    May 2009
    Question
    yeah i have the same problem but i notice it didn't do it for a while until last weekend when i pressure cleaned the engine bay, so maybe someone can figure out where the water is sitting and creating a short.
    VR Equipe II
    Mar 2008
    QLD
    mine used to do the same thing.
    seemed to go away after i changed the ECU but that was a different problem...
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Good grave dig! But Ive seen better.
    On a lighter note, I had that problem. One night driving home the headlights went extremely bright at the same time the battery light came on, almost like high beams. Swapped regulator, nope, problem still there. Then one morning the battery was dead. Tried jump starting it but the engine would die as soon as you took the jumper leads off. New alternator and problem solved.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    Noy
    Noy is offline
    VN SS 5.0
    Oct 2006
    Not sure if its been said yet, but have you checked the connection from the alternator to the positive battery terminal? My connection was loose from the battery, and wasnt charging the battery all the time.
    If its loose, it will cause the battery light to come on and off.
    VR Equipe II
    Mar 2008
    QLD
    haha i didnt even know that it was a 3 yr old thread till u said that ahah
  1. battery light on??
    By vr5l5spd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2007, 11:46 AM
  2. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
  3. Battery Light
    By vl1234 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2007, 09:03 AM
  4. battery light
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 10:28 PM
  5. battery light
    By CSD in forum Electrical Wiring / Questions
    Last Post: 02-06-2004, 08:10 AM
