Results 1 to 8 of 8
Thread: fuel pump probs
    Vz Sv6
    Jul 2005
    Thumbs down fuel pump probs
    hey
    i think my fuel pump has/is sh*tting itself! i had just filled the tank up with vortex and when on the freeway, was at about 100 when i needed to over take, so i tried to accelerate but it didnt want to and there was a whining noise coming from the back end. the car was idleing fine and was not over heating or anything. got home with no more complains. so would this be fuel reg or fuel pump? i no the reg needs changing but the pump im not too sure as i think it was changed about 2 years ago.
    cheers
    jezza
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Fuel pumps tend to work, or not, there's not much of a grey area with them. If you car didn't want to accelerate, I'd start by checking your plugs/leads, and then check the fuel system. Because if it's running okay except for that one time, I'd look at the ignition system first.
    Gravity is proof that nature keeps getting us down.
    Vz Sv6
    Jul 2005
    is the fuel pump meant to make a buzzing noise when the car is on? i can only hear it if im under the car thought. and also if its ignition then why was there that whining noise in the rear of the car??
    cheers
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    the noise is normal but the surge isnt.... have you had any issues since or before
    im not admiring your car im looking in disgust
    Vz Sv6
    Jul 2005
    i pulled over and checked everything out, which seemed fine. so i made my way home with no more probs. just about to go out now, so i soon will no if i will have nemore probs. is it hard to change fuel pump?? if it needs doing.
    cheers
    Frd_thmsn Guest
    Quote Originally Posted by Fully
    cheers
    Try to get your tank under 1/4 saves draining a lot of fuel out.
    I,m doing a pump tomorrow, looks a P.o.P , 6 X 8mm bolts and a couple of hoses , no need to remove the tank.
    Mine has been intermittent, sometimes would whine, sometime car wouldnt start and there was no sound from the fuel pump even when bypassed . Bang on the tank and it would start buzzing again, so I'm sure its the pump.
    Priced some today. genuine Holden $342.00
    Fuelmiser $ 99.00 from ebay
    Some no-name brand $ 69.00 from ebay
    Goss from auto shop $ 90.00
    Vz Sv6
    Jul 2005
    yeah i hope it aint too hard, the only thing is if it dies when i have a full tank that will be annoying! anyway it has been running ok so i will just keep an eye on it. back to worrying about my sway bar bushes and parcel shelf.
    cheers
    jezza
    Hairy Eater's Avatar
    Hairy Eater is offline Banned
    2000 VX Executive V6
    Nov 2005
    Queensland
    if you still got probs... just discon the fuel hose near the engine, put on some fuel line, discon ignition, tun on the ignition key and watch the fuel from into a plastic bucket, put your finger or thumb over the end of the hose to check there's good fuel preasure there...
  1. fuel pump probs
    By iamsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 09:47 PM
  2. power steering pump probs
    By blueballs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2006, 07:35 PM
  3. VN V6 Water Pump probs
    By Capt Baldman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 11:08 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. Water Pump Probs
    By clinker1212 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2004, 07:41 PM
