Results 1 to 3 of 3
Thread: Error 42 - "spark timing" fault
    Irr Guest
    Default Error 42 - "spark timing" fault
    http://techedge.com.au/vehicle/aldl160/vn_aldl.htm
    Describes error 42 as: "Open or short on EST or BYPASS line to ignition module."
    The car is running roughly.. missing a lot when I accelerate, particularly under load. It got worse today and lost a lot of power at the same time, as though it is running on 4 cylinders, perhaps. Spark plugs are new, ignition leads seem to be working, though I'm not entirely sure about that.
    Does anyone have any advice on where to begin? I've replaced the harmonic balancer and crank angle sensor (I thought error 42 was a crank angle sensor error, and had spares of both).
    Could this be a coil pack problem/dfi module fault?
    Or something else entirely?
    Thanks.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Start checking the coil packs and the DFI module. Sounds like something there is playing funny buggers with you. Also, see if you can borrow a mates ECU and memcal to see if that's stuffing you up.
    Gravity is proof that nature keeps getting us down.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Default Error 42 Fault finding
    Hope this helps you out.
    cheers
    Attached Thumbnails Attached Thumbnails Error 42 - "spark timing" fault-error-42.jpg
    Illegitimi Non Carborundum
  1. "check cd error"
    By richardvy6699 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2009, 11:05 PM
  2. "Shift Up" Error message *HELP*
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-09-2007, 05:17 PM
  3. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST)
    By red phase down in forum Electrical Wiring / Questions
    Last Post: 19-08-2006, 06:29 PM
  4. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST
    By red phase down in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 12:00 PM
  5. "SRS Airbag Fault" message
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2006, 07:41 AM
