Results 1 to 22 of 22
Thread: help needed
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Question help needed
    I was drivin along after flogging a falcon wagon and my car just cut out and i couldn't get it to start so after taking it home on the trailer. I checked everything three times over and found nothing. but the check engine light wasn't lighting when turning the car to on. i put a connector between g and h on the dionostics link and the check engine light came on so i tryed to start and it started and now it starts every time????????????????????????????
    VP V8 Wagon
    Dec 2005
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    any ideas which sensors it could be after it started it showed 12 on the dionostics and the CAS and MAP sensors are new.
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    remebering the code 12 is flashed 2 times? then other codes 3 times after that
    12,12,12
    13,13,13 etc
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    VY S2 Berlina
    Jul 2005
    ok just making sure, have you had any injector cleaner stuff put threw the tank etc,does it misfire at all, maybe leads etc
    Current: My Ride
    Previous: Ride 2
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    New plugs last week, New bosch leads 1 month ago, injector cleaner once monthly, is the regulator at the end of the fuel rail vacum activated or should fuel come out the return fuel line if the car is turned off but fuel pump is running.
    why would connecting those pins on dionostic cable fix the problem and moke my check engine light work
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by vpv6wagon
    what you have G and H bridged to be able to start?
    code 12 can also mean a malfunctioning ECU to...
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    swaped the ecu for one out of my parts car. remanafactored delco unit 30 000km since it was redon and put in other car and othe car ran fine.
    now it starts without g and h bridged only bad to bridge it and start it then removed the bridge. i had bridged it before to test the pump and that didn't make a differance it was only when i tryed to start it that it fixed the prob
    Sep 2005
    even though you have swapped ECU's out of your parts car,leave it in yours for awhile and see what happens,or have you already taken it for a drive with it in it?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by samuels
    not real keen on taking it for a drive till i find and fix a problem the mate who owns the trailer is gettin a bit sick of towing my car home
    Sep 2005
    so even with the swapped ECU does it still do this? is it starting?
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
  15. #15
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    it is starting now but only because i put a connector between g and h and tryed to start it while the fuel pump was already going
  16. #16
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    So the fuel pump isn't running without those two wires bridged?
    Yours Kindly,
    Jim
  17. #17
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    The diagnostic link will turn on the engine fan,a/c control relay,torque conv clutch & extend the iac valve. Not turn on the fuel pump. Also when running bridging the terminal puts it in field service mode where the dashlight informs of the fuel loop being used.
  18. #18
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    it wasnt running and when i bridged g and h and started while the link was in so i pulled the link out and now it starts (without the link) dionostic mode is when u short a and b
  19. #19
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Quote Originally Posted by 2Fast2FuriousDude
    it runs without wires bridges now
  20. #20
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Sorry didnt read the post correctly.
    Have you checked your fuel pump relay & wires for a bad connection?
  21. #21
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Question
    my car stopped again today when i was going around a round about fairly fast. and again when i was trying to start it i noticed the check engine light wasn't lighting when i was trying to start the car (like when the ignition is turned to on but the car isn't running). so with the ignition turned to on i bridged d and c (a few blue sparks when i was doing this) looked at the dash and the check engine light was on. so i tryed to start it and it started????
    any suggestions welcome cause im stumped.
  22. #22
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Question
    now it starts every time without the link between d and c?
  1. Help needed Please
    By B J in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2007, 07:53 PM
  2. 308 or 253 Needed
    By vasrox in forum Swap / Wanted to Buy / Trade
    Last Post: 27-03-2007, 07:06 PM
  3. help needed with fan
    By Spury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2005, 02:25 PM
