Results 1 to 14 of 14
Thread: crappy battery
    DAMO_5L's Avatar
    DAMO_5L is offline ILLEGAL
    VN turbo 5L V8 aero, Rodeo minitruck, VR SS 355
    Jan 2006
    maryborough
    Exclamation crappy battery
    this is so crappy. my lights dim to the crapper and then they are ok then they dim then there ok. cd player has not enough power to turn on then it does. i couldnt start it yesterday then changed batteries and it went. now the battery light is on WTF is goin on???
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by DAMO_5L
    so battery light is on with new battery?
    take the belt of,check for bearing noise on alternator,sounds like alternator may be on the way out,check and regulator all earth straps,
    VN Commodore
    Feb 2006
    sounds like ya need new brushes in the alternator. takes about 10 mins to put new ones in.. could be reg like samuels said too..
    DAMO_5L's Avatar
    Jan 2006
    maryborough
    Sep 2005
    yeah its got a new battery and brushes in it. its pissin me off.
    try all earth straps first, battery terminals are on tight arn't they
    could well be regulator then
    May 2004
    put a multimeter on the battery
    car off should be ~12.5v
    car on should be ~14.5v
    leave multimeter on when starting watch voltages drop while cranking
    DAMO_5L's Avatar
    Jan 2006
    maryborough
    Sep 2005
    Sep 2005
    Quote Originally Posted by dodgy
    it should be 13-13.5 all round,it only drops when motor actually running ,to 12 volts,this is how you tell a dicky battery,anything below 12 while motor running indicates a problem.
    May 2004
    Quote Originally Posted by samuels
    Are you sure @!
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    batteries will drop to anything around 8volts sometimes when cranking on most vehicles. but running the car should be around 13.8-14.4.
    May 2004
    "it should be 13-13.5 all round,it only drops when motor actually running ,to 12 volts"
    hakhawk's Avatar
    Jan 2005
    lol, didnt read samuels post properly first, thought he said cranking at 12volts, but running at 12 volts? wtf? that there is sign of an alternator not working. mine runs at 12-13 volts when car is off, and goes to 13.8 when idling. which is the norm.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    agreed, i used to get 3.5V all the time with my old battery =D
    how much do alternator brushes cost???
  1. Crappy gaskets
    By Pure Evil in forum General
    Last Post: 01-10-2007, 12:04 PM
  2. Crappy Computer
    By brownie82 in forum The Pub
    Last Post: 30-04-2007, 06:19 PM
  3. Crappy economy
    By Sphinx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2006, 06:12 PM
  4. Crappy Air Con Temp
    By Slow VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2006, 11:13 AM
  5. Crappy low beam
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-01-2006, 09:14 PM
