Results 1 to 3 of 3
Thread: VQ statesman trip computer
    wookiefunker Guest
    Question VQ statesman trip computer
    does anyone have the owners manual for a VQ statesman series 2 i cant use all the stuff in the trip computer cause no owners manual came with the car any help on resetting the "litres used" in particular would be a great help and does anyone know if this dash would have a digital speedo cause the conventional one is stuck on 90kph .thanks.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    hold down the mode and reset buttons at the same time it will reset everything
    double tap reset to reset a single screen
    hold down reset on each screen for configuration options each should be set at 625 except for the distance to empty wich you can work out if you run outa petrol
    hold down mode when turning on the ignition for special features screens during the trip
    while in that screen you can do a tes on your trip comp by holding both + and - at the same time it will say fail if somthing is wrong
    thats all that you can do oh and there is a switch on the back of the cluster (must be removed to acces it) to change your tank settings from 80l (v8) to 60l (v6)
    then you can adjust the configuration to matchi your tank size eg. v6 have a 63l tank so the switch is on 60 then the config screen should be set to +3 but most of the time this will give an incorrect reading due to old sensors so when you fill up record the liters you add and then get the reading before and adjust so the reading comes out correct after putting the fuel in.
    if you have nay more questions just ask
    im not admiring your car im looking in disgust
    wookiefunker Guest
    Thumbs up thanks
    thankyou very much thats exactly the answer i was chasing your a bloody legend
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  3. SS-V trip computer
    By SV6NZ in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-12-2006, 06:00 PM
  4. trip computer
    By vracclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2006, 09:02 PM
  5. VN/P trip computer
    By jacksien in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2006, 09:12 PM
