Results 1 to 21 of 21
Thread: replacing door pins, hard?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Default replacing door pins, hard?
    hey, my front 2 doors have got the squeaks, the back ones are fine but the front ones squeak badly, ive used WD40, but it fixes the problem for around a week...
    would new door pins fix this???
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    before you go doing that...get the little pipey thingy you get with wd40 and aim it inside the back part of the door (front of car end where the pins you speak of are) and spray liberally onto the hinge that sits inside the door....move the door around a bit and then do the same again.
    this might help...
    also you could try greasing the pins instead of wd40...it would last longer.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    my drivers door started to drop so i replaced the pins now its good all it took was a hammer, drill bit (to knock the new ones in with) and some pliers (to grip and hit with hammer to get pins out) all up took 5 mins to do but i needed som1 to hold the door in position whilst i put the new pins in. but i guess you could support the door with somthing and just do one at a time instead of doing what i did and taking both out then putting both in
    it cost me less than $5 for both pins from motor traders
    im not admiring your car im looking in disgust
    VL Berlina
    Oct 2005
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    manual VN aero
    May 2005
    SA
    no i mean new pins from the large corporation "motor traders" and grease is the go not graphite
    http://www.coventrys.com.au/coventry...motor_traders/
    it seems they are only based in SA
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    manual VN aero
    May 2005
    SA
    lol if you cant find any then ill get em for you and post them to you for $6 total ($5 for pins $1.00 for stamp and letter) or if you want express post (i think is about $3.50 or $4 for under 50 grams) ill do so for $10 (pins @ $5 postage at $5 to be safe)
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    VN
    Nov 2005
    Holden sell them for about $3 each
    Wouldn't recommend hitting them in with a drill bit either use a drift aluminium works good.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ahha nice, but will they fit a VN as i know holden no longer stock VN/VP parts, they're "obsolete" apparently lol :P mine still drives
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    WD-40 dries out that's why it only lasts a week. Use a spray oil like that Nulon Lube Oil stuff. Then it should last longer.
    Yours Kindly,
    Jim
    manual VN aero
    May 2005
    SA
    Quote Originally Posted by jamieaus
    a drill bit works extreamly well and doesnt damage the pin in any way and its the perfect length to avoid removing the door catch
  15. #15
    92 VP Manual "Vacationer"
    Dec 2005
    Quote Originally Posted by 2Fast2FuriousDude
    I agree totally.
    Why not actually use the holden part made for this exact thing ?
    Theres a lube pencil - a bit like a candle except softer and about the size of an autographing texta. Works wonders - doesn't run, doesn't collect dust.
    I'll get the part number.
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    for the door pins, is it $3 each, or $3 a pair as each door has 2 pins (doing front doors thats $12,
    ill go down tommorrow
  17. #17
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ok ok so i went to holden today,
    the door pins are $2.50 each
    you also can get the rubber stoppers as i did, they're $1.00 each
    ok so each door needs 2x of each, so i paid $7 for 1 door...
    what kinda grease do i need?? and do i need to grease them?
  18. #18
    VN
    Nov 2005
    The reason I suggest not to use a drill bit to hit them in is because a drill bit will possible shatter anyone who decides to use a drillbit against my advice please wear safety glasses.
  19. #19
    manual VN aero
    May 2005
    SA
    it doesnt take enough force to break a drill bit just tapping the pins in....... not even for a cheap one
  20. #20
    VN
    Nov 2005
    Feb 2004
    NSW, Australia
    Yep you can buy those waxy sticks from Autobarn, Supercheap.
    But you can buy a tool for around $20-$30 to get those door pins out. Makes the job a whole lot easier.
    Yours Kindly,
    Jim
  1. VS Door Removal - Hinge pins
    By Fletch1102 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2009, 07:17 PM
  2. door hinge pins
    By potshots007 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2006, 02:35 PM
  3. Replacing front door hinge pins...
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 09:22 AM
  4. What to use to remove Door hinge pins
    By Harro_vt in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2006, 11:05 AM
  5. Rusted door hinge pins
    By Stevo-d in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-07-2005, 09:22 PM
