I got a VN engine that has blown head gaskets.. I can get a VP with front end damage and has a good engine... Can I put bonnet, guards, front grill and bumper from the VN onto the VP... or can I put the engine from the VP into the VN and everything will work okay with the VN ECU...
.As long as it is a Series 2 Vn engine you can change them easily. Easiest way to determine this is if the thermostat is at the frount of the motor.
The panels willll bolt up no worrys, but you'll have to use the headlights and indicators from whatever 1/4 panels you choose, as there both different.
Someone else will have to answer about the motor, but i know theres a difference between VN series 1 and series 2, not sure how they compare to the VP though.
Originally Posted by davway
I have a friend who just put a VN series 2 motor into a VP it was a straight swap.
A VN S2 motor is the VP motor so it's a straite swar for vns2 to vp vice versa
