Results 1 to 5 of 5
Thread: Hanbrake Adjustment
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    Default Hanbrake Adjustment
    Okay - I finally re-fitted my handbrake (after about 6 months of driving handbrake-less, i got inspired to fit it after watching some 'motivational driving')
    i figured while re-fitting it i might as well get new shoes for it (which i did), and a few new springs and things...
    so the whole thing is back together now, and i guess you could say it works - but it doesn't work HOW i'd like it to. - in fact, it's kind of weird...
    when the car is stationary, and you pull the handbrake, it works and feels nice and tight with only a few clicks to stop the car.
    now... when you pull the handbrake with the car in motion, the lever is just very very loose... and barely slows the car down at all, when really, this should result in locked rears.....
    my question is - have i stuffed something up in putting the puppy together? or is there more adjustment that needs to be done?
    I tightened that top "separator" inside the drum so that the drum barely fit over it.....
    did that for both sides then i tightened the cable...
    weiiird
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    bump:
    annnd
    can anyone think of WHY the handbrake would be loose when driving, and tight when stationary?
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    try tightening thel cable adjustment and you may find that your diff has exessive movement causing the loose while driving effect.....
    to test this theory you would try using the handbrake whilst your car is facing up a hill rather than testing it stationary down the hillso your diff would in theory be as far forward as it could be causing the cable to slack off
    if this is the problem you have some very bad rubbers up back that need attention
    im not admiring your car im looking in disgust
    VN_Luke's Avatar
    VT, RB30EST VN
    Mar 2005
    but if this was the case... and my diff did have excessive movement, wouldn't the diff slide towards the rear of the car when pulling up the handbrake
    therefore actually TIGHTENING the cable? - in which case it would make the handbrake even harder to pull up?
    or would me pulling on the handbrake be bringing the diff forward?
    I'll test out this hill theorem tonight, that's for the idea!
    manual VN aero
    May 2005
    SA
    ye it is a strange problem im not sure why its working when your stopped and not whilst moving but definatley check the cable adjustment near the end of the gearbox first
  1. handbrake adjustment
    By SweetWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2010, 10:00 PM
  2. Handbrake adjustment
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 07:42 PM
  3. AFM adjustment
    By hertygerty in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2007, 01:15 AM
  4. VS Hanbrake Lever Removal
    By johnsy33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 04:14 PM
  5. headlight adjustment
    By kingswood75 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-03-2006, 01:54 AM
