My Vn Series I has been playing, it idles rough and jerks hard sometimes when i take off. Sometimes when I turn into a street or at the lights, the engines just stalls. Pretty dangerous driving it around at the moment. My mate says it mostly likely the fuel pump not 100% sure yet. The car was playing up similar to this 3 or so months ago. I chucked in a new crank sensor and it fixed it. But playing up again......what could it be?![]()
If the fuel pump was dead, it wouldn't let you touch the throttle at all. They either work or they don't, they typically don't come-and-go for a while.
Check your coil pack/leads/plugs
Gravity is proof that nature keeps getting us down.
how long since the fuel filter has been changedOriginally Posted by VNDAVN
mouce - have have replaced all the spark plus and set of $100 leads. I'v tested the coil pack...its a series II coil pack...i think coils 4 and 6...if thats the middle two coils....they were like a bit under normal watts. So it could be the coil.
samuels - I replaced the fuel filter only about a month ago.....so that cant be the problem for now..
Any more ideas?
Cheers!
Fuel pressure regulator?
Check all your earth straps as well. Also, while you're checking that stuff, have a look for any dodgy connections you might find to the ignition control module.
Yeh today I took the car to the mechanics...he looked at it for like a minute and found the problem. It was the wires coming from somewhere that are connected to the coil pack...the cars like 18, 19 years old..so the wires a bit stuff. It tied it the wires together for now. It seems to have work. No problems yet. Atleast now I know wtf going on.
