Help.
My g/f VN series 1 with a VP motor was running alright. Today it just stalled on her.
I can start it but it idles really rough. when you touch the accelerator it runs even rougher, coughs, spluts and then just stops.
There is plenty of feul pressure and so far everything else looks alright.
Any experiences or thoughts
firstly check fuel you need at least 5 liters in the car to be able to accelerate.... if you have plenty of fuel then its your coil pack simple to replace but not the cheapest part to fail... thats presuming your leads and plugs are good
im not admiring your car im looking in disgust
have a look at the vac line`s going in and out of thrrotle body.
Real cars don't power the front wheels, they lift them
I will check the feul tonight. I am also going to double check the CAS as it was dark last night and under torch light could not tell.
Thanks, i will let you know how i go.
Changed the coil pack. Still the same. Feul is ok.
I can't get it to rev at all and feels like over feuling. Any ideas?
