Results 1 to 8 of 8
Thread: VN v8 Cold Air Intake
    VN Calais 5.0L
    Feb 2006
    Default VN v8 Cold Air Intake
    Hey guys,
    I installed a pod filter this weekend to the clais, only to be very dissapointed (then i read the threads!! hahaha!!!) i have since removed and re nstalled the stock setup....
    I am going to get a K & N panel to sit in the box, and am planning a vs v8 cold air snorkle (is this as good as the ss inductions one?) but my question is...
    Has any one cut a hole beneath the airbox to run some ducting to pick up from the from air dams??
    There seems to be a fair amount of structual metal between the box and the air dam, and is it illegal???
    What size and type of ducting would you reccomend???
    I remember back in 97 my first vl (of 5!!) i cut a hole beneath and used 4 inch plumming pipes and fixtures and used a larger collecter to get a "venturi effect" with good results...
    Is the too inlets too much? would the vs/ss intake be sufficient??
    Thanks Guys
    VP Executive R-spec
    Jan 2005
    Yes Dave the VS V8 one is good, better if you open up the mouth of it a bit with a heat gun and some tools, but you could make a better setup if you sat down and thought about it, alot of people cut out the bottom the the air box right though the car but I wouldn't do that. Probably not legal as you say and to do that to a VN V8 would be criminal anyway
    How much power did you loose with the pod? fairly massive in the day time isn't it
    VN Calais 5.0L
    Feb 2006
    Green, when i first ran the pod it was similar, but after a few minutes the engine bay heated up and it was quite sluggish....
    I have run some 1.5 inch pipe from the opening in the airbox from the air dams in bumper till i find a suitable solution.....
    What is the best panel filter these days???
    When i did the cai in the xr8 i used a foreign brand, cant remember the name but i was marketed by ss induction, it seemed to flow really well...
    VP Executive R-spec
    Jan 2005
    The K&N filter is made of like cheese cloth you can see straight through it if you hold it up to the sunlight (all little holes) so you need to have faith in the oil to seal up those holes, but it does flow very well as you would expect, If I was going to do a proper CAI I'd make a new bigger airbox from sheet metal or some kinda fiberglass then run a large K&N pod filter inside that with large ducts comming into it from in or under the front bumper, but the stock VS parts are ok for now
    nsladden's Avatar
    nsladden is offline GET UTED
    1992 Holden VP Ute S 5.0L & 1989 Holden VN 5sp Wag
    Sep 2005
    Murwillumbah
    VN Calais 5L
    Dec 2005
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by projectaero
    u thought about going the VS SC CAI setup ?
    It wont fit over the V8's fan shroud, the V8 one is just as good once you hit it with a heat gun anyway
    VL
    Jul 2005
    SA, Mount Gambier
    I have a vn-vs v8 cai on my 6, your right tho foamy bout opening her up a bit, i wondered how air got in there at the start lol.
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Cold Air Intake
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 08:42 PM
  3. Vr Vs Hsv Cold Air Intake
    By bomner12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 08:53 PM
  4. Cold Air Intake
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 09:25 PM
  5. VP Cold Air Intake
    By habro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 06:26 PM
