Results 1 to 21 of 21
Thread: Putting a v8 tank into a v6 commodore...
    DioXidE's Avatar
    DioXidE is offline 6L of FUN!
    VE SS-V M6
    Jan 2004
    Default Putting a v8 tank into a v6 commodore...
    Hey guys,
    Going to put the v8 tank (80lt) into the v6 commodore as I need the extra fuel capacity...
    Will the std v6 fuel pump/level sender fit fine??
    Arif
    VE Commodore SS-V [SKD55] ► Phantom Black ► Redhot Leather Trim ► 6 Speed Manual ► 282 RWHP Stock ►
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Let us know how it goes, it's a mod that I've been looking at for a while, only problem is that I can't find the 80ltr tank anywhere.
    Gravity is proof that nature keeps getting us down.
    VN Commodore
    Feb 2006
    if anyone wants one of those tanks i have one for sale.. PM me with an offer if you want it....
    DioXidE's Avatar
    VE SS-V M6
    Jan 2004
    i got one off ebayy for $100
    VT Equipe
    Nov 2004
    Tullamarine
    The fuel sender & pump fit fine, but the fuel gauge will be out. The height of the 80 ltr tank is heigher, you might need to bend the float wire to reach the bottom, otherwise you will show empty when there is still 15 litres in the tank.
    Jun 2005
    Quote Originally Posted by joebloggs
    simple solution. upgrade to a calais dash
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    redcedar's Avatar
    redcedar is offline workaholic
    Alto Grey MY12 SS
    Nov 2005
    coffs harbour
    Toyota Supra Turbo
    Dec 2005
    SE Suburbs, Victoria
    are these '80lt' tanks pretty common or rare as hens teeth?
    Adam
    1990 VN S1 V6 Calais (SOLD!)
    1996 Toyota Supra Turbo
    mouce's Avatar
    Jul 2005
    That'd be good. It means that you're never letting it get to the really 'dirty' fuel at the bottom of things. That of course assumes you look at the fuel gauge, and let's face it, they aren't really accurate.
    1991 VN Commodore, 1997 VS Statesman II V8
    Jun 2005
    I think they are terrible fuel gauges( i hate sayign anything bad about holdens). I see so many people smashing the S$#T out of there dash because the needle is playing up
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    The tank itself will bolt straight in, use the v8 sender and put the v6 pump onto the v8 sender. If the gauge does not read right you can get it re caliberated by and dash instrument place. Or as said before convert to a calais dash and set it to 80L, if you a have a calais just set the dash to 80L and jobs done!
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    I think the venting for the 80 litre tank is different too so to do it properly you need the right filler neck and associated hoses as in the pict below.The tank itself has one less small vent hose feeding the tank.The front of the tank itself also has a plastic protector that gives the front of the tank some protection from stones etc.The steel tank straps dont use any rubber under between them either and the tank too and they are u shaped and not flat like the smaller tank.If you use the sender from a large tank the gauge on the dash will read the same....the actual gauge is the same between v6s and v8s in the cluster as in the resistance readings from full to empty....just the arm on the float since the actual tank is deeper.
    You can check it your self by putting the sender in and putting a ohm meter across the sender....283 ohms empty 97 half full and 40 ohms full.
    Attached Thumbnails Attached Thumbnails Putting a v8 tank into a v6 commodore...-fuel-tank.jpg
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Jun 2005
    The tank in the pic i believe is vr-vs, because the vn-vp 80L tanks still run the 2 small hoses as per v6 fuel tank. I didnt realise the fuel gauges were the same, but you learn something every day. I guess the swith on the calais is just so the trip meter can calucate distance to empty etc. and not actually for the fuel gauge itself.
    Nov 2003
    northside brisbane
    Yep it is a vr/s one ..thats the one for my car.The pump setup for the different models is a bit puzzling.The vn/p 80 litre tank uses 2 fuel pumps...one high pressure and one low....the vr/s uses one high pressure and thats all.Any ideas why they did this?
  15. #15
    Jun 2005
    One could only guess it was to save money on the assembly line! I cant think of any other reason because the vn-vp set up seams to work fine on the v8's.
  16. #16
    VP Executive R-spec
    Jan 2005
  17. #17
    Jun 2005
    Quote Originally Posted by greenfoam
    Do all the V8's run an 80 liter tank? or was it an option
    I am pretty sure that all v8s run the 80L tank.
  18. #18
    Wonderboy Guest
    yesum, the v8 80l fuel tank has 2 pumps one in the tank and an external one that runs lower psi its like primary and secondary. if any of you blokes figure out how to convert the 63l to the 80l v8 one give me a yell.
    my mates old man is a truck tanker welder and made his drop tank its approx 130l or something rediculous like that. but he runs the standard pump into a smaller surge tank in the boot then runs an external holley fuel pump to the rail. im not sure what he did with the float...
  19. #19
    Nov 2003
    northside brisbane
    I installed the 80 litre tank into my v6 that previously had a 63 litre one and it runs fine...using one fuel pump...in the factory book it only mentions one pump for a vr 80 litre job.
  20. #20
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by Wonderboy
    straight bolt in jobbie, but make sure you use the 80l straps, as the 63's won't fit
  21. #21
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Hey i got a question, My car is stock Vp Commo, I fill it up every 2 weeks with still not hitting the red and it takes on 68LT once it took on 71LT.
    I about 2 months ago got a rear muffler fitted, A stock VP also was there, His tank was smaller then myn, But it is no way 80litres.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  1. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  2. putting my amp in
    By Ben. in forum Car Audio
    Last Post: 15-02-2007, 09:39 PM
  3. Help!!! Putting fuel tank back in with new breather hoses..
    By Kartbro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-01-2007, 11:25 AM
  4. Putting a 3.8 into a VK
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-05-2006, 08:34 PM
  5. Putting fan belt on VN commodore
    By happy2play23 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 10:24 PM
